Old 16th April 2006, 12:18 PM   #1
Default perreaux 3000b burning resistors
hi everyone
im new here, and arent really familiar with MOSFET amps, as im a tube guy, but bear with me
ive got a perreaux 3000b amp that needed fixing, as the right channel distorted. THAT was fixed easily enough after a bit of dusting and fuse swaps. the left channel however after the fuse swaps now tends to catch fire when a load is connected.
the first fuse holder, the one straight from the power point was a bit bent or stretched or something when i put the a fuse in, so there wasnt an excellent connection, and the 180R resistor inline with the diode coming from the big filter caps and the 270R resistor coming from the emitter of 2 BJT transistors earlier in the circuit went up in smoke. i replaced both, and now the 270R one keeps burning, but the 180R one is fine. id post a schematic, but perreaux dont seem to like handing out copies, but if im desperate, i can email it to you.
any ideas? im at my wits end with this haha. also, there are 2 trimpots in the circuit. how should these be set?
thanks ALOT
james
Old 16th April 2006, 02:38 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi James,
We will need to see the diagram. I have repaired a couple Perreaux amps over the years, but those were ages ago. Parts from Oz are expensive here due to shipping costs.
You could email me a copy at bhomester at gmail dot com . There is most definitely another problem in there.
-Chris
Old 17th April 2006, 07:42 AM   #3
good news!! the fires have stopped
NOW i believe i have got something misbiased. i think that because i get a BRUTAL buzzy distortion, and i only get that when i bash the strings hard (im using a bass to test it, as thats what it gets used for). ive come across this in making guitar effects, and i know that it can be fixed with an easy tweak. problem is, im not sure what to tweak.
i managed to stop the resistors burning by replacing a stuffed transistor. i replaced both the transistors in the pair, just in case. the originals were labeled PLSN - not much help, so i took a punt and figured they were just common small signal NPNs, and replaced them with a pair of BC458s. i happen to know that they are pretty high gain transistors, and i also had to make a 'close enough' resistor because i burned all my 270R ones. i currently have a pair of 560R in parallel. they come from the emitters. is this enough difference to affect the bias?
Old 17th April 2006, 08:58 AM   #4
srh is offline srh  New Zealand
Hi James,
IIRC the PLSN is a house coded MPSA42 and the PLSP is a MPSA92.
Steve.
The older I get, the more simplicity appeals.
Old 17th April 2006, 12:57 PM   #5
anatech's Avatar
Hi James,
As Steve posted, there is a large difference in Vce. Replace them right now before more damage occurs. If you have to get the transistors, get the proper resistors (your current value should be close enough)
RV1 and RV3 set the bias current, RV2 and RV4 set the DC offset. Match the current draw of the blown stage to the good stage. If you call Perreaux they should be able to tell you over the phone.
Hint: Turn the amp off and discharge the filter caps through a resistor after letting it sit a bit. Replace one fuse on each side with a 1R0 or 0R1 resistor, I like to use 2W or better. Measure the voltage drops.
-Chris
Old 18th April 2006, 11:12 AM   #6
alright the fires are back. i swapped the transistors out as soon as i read your post after a brief moment of panic. i put the transistors from the good side in, and the resistors went up in smoke again.
i noted the voltages are high on the pair of NPN transistors, most notably where it should be 7 volts, its about 30 or 40.
i cant get MPSA42s where i live, but the MJE340 looks pretty close, are these a suitable replacement?
also, is there a possibility i nuked the output transformers?
heres the schem for you, sorry perreaux.
Old 18th April 2006, 11:53 AM   #7
Audio Junkie
Zero Cool's Avatar
WHAT your using a perreaux as a BASS AMP???? OMG that poor amp. such a nice piece of audiophilia being bashed about in road rack. Oh the horror. Thats like using the hood of a Porsche for a work bench or saw horse!
I had heard rumours of guys using Brystons for PA's and Bass rigs and even saw a photo of a rack of Brystons at the Sky dome in Toronto for the PA and that was shocking enough but oh my...Somebody please rescue that amp and give it the precious home it deserves!
I'm going to go cry now..
Old 18th April 2006, 11:56 AM   #8
Audio Junkie
Zero Cool's Avatar
On a more serious note. check for oscillations. the Hitachi output mosfets have a tendancy to go bad when drive hard. the gate capacitance goes crazy and the amp will start to oscillate causing the driver stage to draw LOTS of current.
Been though the same thing with Big Haflers that were used as subwoofer amplifiers in Theaters. they would beat the crap out of them and they wouldnt last long.
Old 18th April 2006, 01:22 PM   #9
anatech's Avatar
Hi James,
Get the parts from Perreaux then. MJE340 might be a bit slow but you never know.
If the gate resistors are burning, the output FETs are shot. BTW, never swap parts from a working channel into a non-working channel unless you have an awful lot of experience. It would involve testing those parts first as well.
Hi Zero Cool,
I have seen many over heated racks of Bryston used for various things. I don't care for those amps but I do agree that they do not do as well in those applications as the Pro amps designed for that abuse. While I do question the use of a Perreaux as a bass amp, it is James' amp. I do expect those clamping zeners to conduct on a semi-regular bassis.
-Chris
Old 19th April 2006, 11:48 AM   #10
righto back with more info.
im preeeetty sure the output FETS are buggered. i did an in circuit test and on the good side, all the FETS measure infinite resistance gate to drain and gate to source. on the blown side they measure infinite gate to source, but there is some low (about 400 ohms on some, about 100 on others) resistances on gate to drain. im fairly certain that means theyre stuffed.
so apparently you cant get these 2SK135 and 2SJ50 transistors any more. the best i can get is 2SK1058 and 2SJ162. i had a quick look at the data sheets, and they look pretty similar unless ive missed something, but ill leave the final decision up to you more experienced folk. if they arent any good to me, what can i use as a substitute without having to scrounge around for NOS items?
as for using it as a bass amp, well its a mates amp, and it sounds bloody good!
The Burning Amp Festival-Burning Gadgets Preview Zen Mod Everything Else 115 27th October 2007 05:50 PM
Page generated in 0.12278 seconds (83.96% PHP - 16.04% MySQL) with 10 queries
