#21 |
It looks like the ML2 spec you are quoting shows that the ML2 cannot pass it's maximum ClassA output current into a 2r0 load.
14.14Vpk & 7.07Apk into 2r0 is that 50W into 2ohm. This is -5dBV relative to the specified 80W into 4r0.
regards Andrew T. |
#22 |
4 Amps peak shared by eight complementary powertransistors.
That's 128Watts peak and 64watts RMS Class A power for a 2 ohms load. Then it's going into Class AB for the remaining 80 Watts or so. |
#23 |
post18 & post22 state different values.
regards Andrew T. |
#24 |
That's correct because the initial writer of this thread explained that he only could get .50 Volts at the Testpoints meaning 50/56 = 0.9 amps bias at each TO3 instead of the specified .56V which would give 1A.
3.6 Amps bias gives you a tad over 50 watts Class A at a 2 Ohm load instead of the 64 Watts with 4A. You can do the math yourself probably. |
| Mark Levinson №27.5 | Taifun | Solid State | 101 | 14th March 2011 09:57 PM |
| Total newbie post - trying to replace ext. PS on vintage Mark Levinson ML-1 preamp | yamezxx | Power Supplies | 3 | 26th August 2009 04:29 PM |
| Mark Levinson no:29 | Snorkeltjes | Solid State | 19 | 24th November 2007 12:18 PM |
| mark levinson | karma | Swap Meet | 8 | 8th March 2003 01:42 AM |
| Mark Levinson ML2 | arnach | Solid State | 7 | 9th April 2001 04:36 PM |
| Page generated in 0.07871 seconds (68.96% PHP - 31.04% MySQL) with 11 queries |
