Old 15th April 2006, 03:34 PM   #1
pwan is offline pwan  United Kingdom
Default 100W amp: Leach amp or P101 ?
Hello,
I currently have 40-0-40 480VA and 6x 6800UF, I wonder which one ( Low-tim Leach amp, and P101) is suitable for my 88 db/w/m speaker and classic/pop music?
Thanks.
Old 15th April 2006, 04:20 PM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Depend on your DIY experience.
Old 16th April 2006, 03:06 AM   #3
P101 seems to be simpler, however, I found Leach kit available at reasonable price. As far as sonically concerns, which one is your recommendation?
Old 16th April 2006, 06:50 AM   #4
you are short of smoothing capacitance.
You will need a minimum of +-10mF/channel for 8ohm speakers. i.e. 4off 10mF or 8off 6m8F
If you have 4ohm speakers, you need to double the minimum requirement. This will also apply to 4 to 8 ohm speakers since it is the bass unit that tends to be the 4ohm part. 4ohm bass units need 8off 10mF or 12off 6m8F.
There are three ways to arrive at smoothing caps:
1. 2mF/Apk output current. (based on nominal impedance or DCR)
2. 1mF/10W output power. (40Vac will give about 140W)
3. PSU RC time constant >1.4*NFB>1.4*input hiPass. (aim for 1 to 2Hz on 4r or 8r)
regards Andrew T.
Old 16th April 2006, 10:26 AM   #5
My friend just offer to trade his 4x 10,000UF 63V with my 4x 6,800UF 80V. With 40-0-40 transfer produce ~ 58Vdc, Is it safe to use with 63V cap?
Old 16th April 2006, 10:38 AM   #6
allowing +5% for transformer regulation and a further +-6% for mains supply variation brings 40Vac right up to the 63Vdc limit.
So the answer is yes, use 63Vdc on 40Vac.
That gets you in the ballpark of about 130W to 140W into 8ohm.
regards Andrew T.
Old 16th April 2006, 11:50 AM   #7
I see. I will use 4x 10,000UF 63V for 40-0-40Vac traf then
Andrew, Many thanks.!
Old 16th April 2006, 02:43 PM   #8
still4given's Avatar
Actually Rod Elliot recomends 6X4700uf 80V for the P101.
I asked him when building mine if using 6X15000 whould improve things and he told me no. I used them anyway since that is what I had.
I think the Leach is a little more HiFi sounding than the P101 but it needs more heatsink than the P101. At least mine does.
Link to the PSU schematic at the bottom of the page.
Blessings, Terry
Old 16th April 2006, 03:12 PM   #9
still4given,
Thanks for your comment. BTW, you might consider removing the schematic above as it's Rod's intelectual property. :-)
PS: I sending you an email. Could you check it out? Thanks.
Old 16th April 2006, 04:37 PM   #10
djk is offline djk
djk's Avatar
"you might consider removing the schematic above as it's intelectual property"
Looks like any other power supply to me.
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Esp P101.................... Gavinator68 Solid State 66 8th February 2011 05:44 PM
FS ESP P101 Amp john65b Swap Meet 3 26th February 2008 07:24 AM
esp p101 djronbxs Solid State 2 6th January 2007 01:02 AM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
Page generated in 0.10148 seconds (81.88% PHP - 18.12% MySQL) with 10 queries
