Lundahl are bringing out some more amorphous core output trannies for *tube amps.
The Aksa website FAQ says: “We are using 160 VA transformers with amorphous cores, and they perform outrageously well. The bass and image depth is really so much more remarkable than one quality 300 VA toroid.” For SS amps, who makes amorphous core power trannies, eg 160/ 225/ 300 VA? Anyone used any? Thanks Richard |
#2 |
#3 |
Where do we get 'em?
#4 |
I'm also using amorphous core transformers in my amps, but comparing to quality toroids the difference definitely isn't outrageously remarkable.
While one gets the impression of increased resolution and better soundstage with amourphous core, the bass is about the same. Now, comparing cheap toroids from China with Plitron toroids the difference in bass was indeed remarkable (the Chinese TX was much worse in bass definition and PRAT). As Jonathan Carr says here: http://www.diyaudio.com/forums/showt...0531#post80531 the actual choices in main filter caps make probably bigger difference than amorphous core transformer. I'm sourcing mine from small factory in Europe.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
Hi Peter
(I was thinking of using them in an active three way, for the mids & tweets, so the bass is not an issue). How do the prices from Europe compare with eg good torioids; can you say who? |
#6 |
I'm paying about the same for amorphous core 300VA toroid as for 300VA Plitron. I'm getting them from here: http://toroidy.pl/
Also, my version has thicker secondary wire, and primary over secondary. Here, how both compare sizewise: The only problem is the high cost of shipping.
#7 | |
Banned
Witch one is better tho |
#8 |
In the amps I'm building for myself, I'm using amorphous core toroids (on the left). As I said, the difference is not outrageously remarkable, but those transformers have certain performance edge over the stock Plitrons.
#9 | |
Banned
Not a topic i want to get into |
#10 | |
| Need Amorphous Core Matching Transformers for Ribbon Drivers | NV&H | Planars & Exotics | 19 | 16th July 2008 07:53 PM |
| Plate choke material, why to use amorphous core? | noyan | Tubes / Valves | 5 | 7th July 2008 12:25 PM |
| amorphous iron core good or not | nhuwar | Tubes / Valves | 12 | 28th April 2007 04:00 AM |
| Amorphous core transformers only work above 20KHz? | edonion | Tubes / Valves | 12 | 23rd November 2004 11:30 PM |
| Page generated in 0.12088 seconds (74.69% PHP - 25.31% MySQL) with 10 queries |
