Old 14th April 2006, 11:18 PM   #1
psyche is offline psyche  Greece
Default Amplifier upgrading!!!!!!!!!
Hi there,
My name name is Padelis and I am from Greece.I electronics here in Greece and I decided to build and amplifier for my home project studio.I bought a kit from a company here in Greece which is an 2x60watt amp.On the schematic the output transistors are bdw83 and the provided transistors are 2sd817(upgrade???).So what i want to ask you is what to do in order to make this amp better.I would like less distortion, more watts and be a little faster.I know that if i want to change the output transistors i will have to change the drivers too.So here i am to the more experts diyers asking for help and opinions!!!!
Thanx in advance
Padelis.
Old 14th April 2006, 11:35 PM   #2
quasi is offline quasi  Australia
quasi's Avatar
Default Kalimera Padeli, ti kanis;
Can you please attach a schematic. It will be easier for people to offer advice.
Cheers
Old 15th April 2006, 12:26 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Maybe you could use a complementary design instead of quasi. Not that quasi is bad, it's just that there exists in these modern times some pretty good complementary output transistors.(no offense quasi ) You may not have to change the drivers, just use them in emitter follower darlington arrangment. Also wouldn't hurt to add small base resistors to those outputs. In doing this, you may also want to include a Vbe multiplier for bias and thermal stability instead of diodes as class AB emitter followers can be sensitive to temp. and bias changes. Loading the VAS with a current source might work also, however there are designs that don't use a CCS.
All the trouble I've ever been in started out as fun......
Old 15th April 2006, 01:21 AM   #4
quasi's Avatar
It seems as though you have already bought the amp kit.
The BDW83 is specified as a darlington and I cannot find information about the 2SD817. A more modern transistor would be a TIP142.
The number of changes required would not work well with the existing kit PCB so I would build as is and see what you think.
Use any upgrade money you have to build an excellent power supply using a 500va transformer with a seperate bridge and capacitor bank for each amp module. Use at least 10,000uf per rail (20,000uf total) per amp module.
Cheers
Old 15th April 2006, 01:24 AM   #5
quasi's Avatar
Offence? me?
None taken CBS240. I actually like complimentary transistor output stages. For high power I prefer quasi-comp because watt per buck it's hard to beat.
Cheers
Old 15th April 2006, 01:27 AM   #6
darkfenriz's Avatar
Looks like from early seventies. Not a nice idea to build an amplifier like this. Try something else, more worth bothering.
regards
Adam
Old 15th April 2006, 08:04 AM   #7
persist with the kit and get it working. I do not recommend spending extra money modifying this rudimentary quasi design.
As Quasi said build a good supply and case and allow for a new amplifier PCB to be substituted later.
regards Andrew T.
Old 15th April 2006, 08:39 AM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
psyche:
That circuit is really terrible (not due to the quasi output stage but due to the lousy rest) and probably from early seventies as it has ben already pointed out. Also, ECA book tells that 2SD817 is a Toshiba 1500V 1.5A TV horizontal deflection transistor, thus not suitable at all for an audio amplifier. Furthermore, Toshiba electronic components website does not contain any reference to that device (meaning that it was discontinued a long ago) and I couldn't find any other alternative manufacturer in google, so what you have are FAKE transistors, forgeries (very common in Southern European countries).
In my opinion you have been scamed, so it would be a good idea to return everything to the supplier and ask for your money back.
Also, remember that this forum is full of great projects to build, you just have to be patient and search. You should also search for threads on fake components and read them because I feel that local stores on your country are flooded of fake transistors and ICs (as it happens in Spain and Italy).
Old 15th April 2006, 09:59 AM   #9
bogdan_borko's Avatar
Oh man, who sold you that kit in 2006. ???
Old 18th June 2006, 02:52 PM   #10
Hi there,
soryy for been away for soooooooooo long but i had completely forgot that thread.a few corrections:
the output transistors are 2sd718
I have built this amp a few months ago and it sounds simply good.I was just wondering if i could improve its performance, thats all! Now i am ready to build a new amp from the schematics that are posted here in the forum but i can't decide which one to build.These are all great.BTW what would you recommend me to build?Have in mind that i will use it in my studio.
Thank you guys you are great
Padelis
Upgrading an op amp in mic pre?? synap2012 Chip Amps 3 7th May 2008 02:26 PM
Upgrading DM2 beamnet Multi-Way 2 7th December 2007 03:00 PM
Upgrading parts in an integrated amplifier imperfectcircle Solid State 9 15th February 2007 10:44 PM
Upgrading R50 KEF TL essence Multi-Way 26 29th January 2007 09:15 PM
Page generated in 0.18374 seconds (51.48% PHP - 48.52% MySQL) with 11 queries
