Need help for amplifier conception
Old 20th November 2002, 12:05 PM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Need help etc
Bricolo,
You need help? You're kidding..!
Chapeau! (Couldn't find the smiley that takes its hat off)
Jan Didden
Old 20th November 2002, 08:09 PM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I can't tell if you figured this part out: The output impedance
of the Source pin is the inverse of the transconductance
of the Mosfet, and from your curve we see the transconductance
to be about .2 amps per volt, for an output impedance of
about 5 ohms. Your bias resistor plus headphone will load
this down, and it would appear that they represent something
like 15 ohms, forming a voltage divider that gives a .75 gain.
Old 20th November 2002, 08:53 PM   #13
Bricolo is offline Bricolo  France
Bricolo's Avatar
I didn't understant everything you told, Nelson
I'll try to find more infos about this transconductance
I didn't take care of the mosfet own resistance.
The yellow line is only calculated by 1/R4
I've just done some mesures with the CCS modified circuit.
I've got some weired results
My V4=f(Vg) graph is a line going up slowly, still Vg=6V
from Vg=6 to 12, it is a line, going up faster
I think the 1st part is when the LM317 hasn't reached 250mA (I set it to 250mA)
The lm317 is not a perfect current source
it's more like a current limiter
that explains why we got 2 part for the V4=f(Vg), a first one when the 317 hasn't reached 250mA, and another one when it limits the current to 250mA
I can't mesure the current to prove this, but I'm quite sure it's that
Old 20th November 2002, 08:55 PM   #14
Bricolo's Avatar
Nelson: I found nothing about transconductance in the 2SK's datasheet
Old 20th November 2002, 09:32 PM   #15
traderbam is offline traderbam  Europe
traderbam's Avatar
Lightbulb general definitions
Reciprocals:
Resistance Conductance
Reactance Susceptance
Impedance Admittance
Ratios:
V/V voltage gain, no units
V/I resistance or impedance, ohms
I/V conductance or admittance, mhos or siemens
I/I current gain or beta, no units
A trans[ratio] amplifier converts ratio denominator (input) to the ratio numerator (output).
Eg: transconductance of a FET is I(out)/V(in) or Id/Vgs
Old 20th November 2002, 09:48 PM   #16
The one and only
The curve you posted and the region you indicated gives
us the information. .5 volt difference Gate to Source gives
another 100 ma Drain current. This is a 200 mA/volt figure,
and becomes .2 A/V
Old 21st November 2002, 06:16 PM   #17
Bricolo's Avatar
Nelson
I made no calculations about the mosfet transconductance
just: 12=Vds+R.I
so I changes with -1/R
that's all
you see on my xls file, on I=f(Vds)
the line's equation is -45
-45/100 (mA) is equal to 1/22Ohm
Need help for amplifier conceptionHide this!Advertise here!
Conception of a lcd volume display for dummy skappy Chip Amps 7 3rd November 2005 02:39 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
Copyright ©1999-2017 diyAudio
