Musical Fidelity MVT mk3 preamp line-stage
Old 26th November 2009, 12:12 PM   #31
rmgvs is offline rmgvs  Netherlands
Default it's the grounding stupid!
A rather long journey comes to an end. Problem of noise solved. Rerouting the ground of the power supply by just a few inches solved the problem. Lesson learned: i did know that grounding is crucial for hum, but now i know it also can cause hiss. The preamp is quiet now and plays as it should, comparable to the original one.
Old 1st March 2012, 11:45 AM   #32
snedevigM is offline snedevigM  Denmark
Default Diagram of MVT MK2
Originally Posted by jez View Post
Small heatsinks are used for output devices but not any others in MVT.They run pretty hot so are probably needed.
P.S. MVT= (I am fairly confident) Micheal Vaughn Thomas, also designer of the Dr. Thomas power amp and original "The Preamp" from MF....just for info
Hi
Do any one have the original Diagram of this MVT MK2 ?
Musical Fidelity MVT mk3 preamp line-stageHide this!Advertise here!
Musical Fidelity preamp p3a hoshy Solid State 44 4th December 2015 10:06 AM
Musical Fidelity A2 preamp AD797 oscillate sviru Solid State 23 5th November 2012 01:05 AM
Musical Fidelity The Preamp mosfet1 Solid State 0 12th December 2006 11:22 AM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
line-stage preamp tubes? which ones to use... RockysDad Tubes / Valves 12 18th March 2005 12:10 AM
