Quick question about Sansui. I have the opertunity to purchase an AU 555A amp and a QS-100 4 channel rear amp. These are going quite cheap, as in under $100 for the both of them. Do you think its worth it or are they just too old? I'm not to up on these things so any help would be appreciated
Cheers
Brett
Cheers
Brett
Hi; by the look of the amp itself and the model# of it is quite old from the '70's l'd say dunno 'bout the rear amp so go easy don't get too carried away.... with the prices [ buyer beware]....Sansui made some reall classic and highly regarded gear in it's time so it may be worth it to you but bear in mind sansui is defunct in all but name on the other hand others may have a different opinion, better wait till you get some more responses from this erstwhile forum ohhh there is one tiny thing to consider these amps were not directly coupled o/p is through a capacitor if memory serves me right though they were decent sounding for the time cheers TC
I don't know if this helps, but I think that "any" of the 70's Sansui products are probably a good value if the price isn't too high and it's operational. Here's a bit from a previous post.
http://www.diyaudio.com/forums/showthread.php?threadid=60122&highlight=
My little contribution is in there.
Best Regards,
TerryO
Best Regards,
TerryO
Hi Endzone,
The old Sansui amps from the 70's are very good and built well. However, the parts may be old and may require some upgrades. A cap replacement can definitely improve things, also some transistors may be on their way out and obsolete, but suitable replacements can be found with help. You may need to factor this into the price.
I hope you find these links helpful in making your decision
http://www.sansui.us/Amplifiers.htm
This site has some support for Sansui owners
http://amp8.com/sansui/au555-20000/au555.htm
cheers
Richard
cheers
Richard
I'm in love with my Sansui TU-717 tuner and AU-7900 amp.
The tuner flat out -Rocks!- It's better sounding,and more sensitive than any other tuner i've used.
The amplifier is built like a tank,and still works and sounds great after all these years.
Sansui made some quality gear. If the price is right (cheap),I'd say go for it. (Just don't let the wife know!)
- Sansui Products
