op-amp based preamp advice needed
Hello everybody!
I need a good preamp, line and RIAA stage. As for the line stage, I need approximetely 6 dB of amplification. I just browsed the solid state forum looking for a simple answer but, unfortunately I got more and more perplexed :bawling: So there are few questions: - what op-amp for RIAA stage (I thought about AD 797, would this one be a good idea?), anyone got good shematics for this? - what op-amp for line level, after reading, reading and reading the forum I have three favourites: OPA627, AD825 and AD6810. Simple question, considering the ideal aplication for each three, which one would be the 'ultimate'??? - I guess I need buffer. BUF634 or antyhing else? Or maybe a discrete buffer? Any schematics welcome. - Power supply. I guess it's very important. Would battery PS be a good idea? Where can I get schem. for circuit that would load batteries when empty? - Volume control. Actually I want it to be IC-based, but how about the sund of such ic-based volume regulators? Sorry for such a lame questions, but finally I have some time and just want start some soldering ;) Thanks, Adam ;) ;) ;) :) |
If you are looking for a work horse, check out OPA134/2134/4134 from Texas. This opamp can deliver rather much current also. The noise level is sufficient for MM RIAA amps but for a little bit lower noise, check for a opamps with 2-6 nV/SRQHz. Less than 1 nV is needed only for MC pickups.
OP37 LT1028 LT1128 LT1115 AD797 NE5534 (not so bad!) plus many more.... |
Thanks Peranders,
but I am looking more for a specialized audio op-amps, dfferent for RIAA and different fo Line levels. I assume that because the difference in signal level between phono and line I will need different op-amps to meke the most of the signal am I right (I mean that the different op-amp will sound the best in RIAA and different in 'live-level' application)? Adam |
OPA134 and others are very suitable for audio, read the datasheets to be convinced. Almost any opamp with slew rate >5v/µs will work but some works better. Some opamps are more suitable for "gain" than others. These are often not stable at gain lower than 3-10. Check for instance LT1028.
OPA134 will work for everything except for extremely low noise applications. I have put in OPA134 in my headphone amp (QRV-02) and I am impressed by it's technical clean performace. The step response is perfect down to gains at 1. |
Peranders,
What do you think about AD6810 and AD797? Greetz, Adam |
AD797 is a typical opamp for phono/mic stage |
Peranders,
I would have to pay about 8 $ for AD8610. I think I'll go for this one certain op-amp ;) As for AD797 - i though about using it in an RIAA circuit, would this be a good bet? Greetz, Adam |
If you don't plan to connect MC pickups AD8610 is quite sufficient, if we talk noise.
2 Attachment(s)
Hi Adam,
I have a PCB layout that would let you use either an OPA627 or AD825 with a BUF634(TO 220 package) on the output. Below is the schematic: G |
2 Attachment(s)
Here is an image of the PCB:
G |
| All times are GMT. The time now is 11:26 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
