Hi all.
the voltage on a Capacitor fed from DC through resistor builds up asymtotally towards the DC input level. By the time one RC time constant has expired the Cap voltage will be about 70% of the DC feed voltage. If one builds a 2pole or multi pole low pass filter to monitor the DC offset from a power amp rather than a single pole filter, it becomes difficult (for me) to calculate the time delay for the final cap voltage being fed to the trigger circuit. Q. is there a simple way to simulate the voltages vs time on the capacitors as the DC voltage feeds through a multi-pole RC low pass filter?
regards Andrew T. |
#2 |
why don't you use a circuit simulator ? |
#3 |
I have not learned how to yet. Will it/they give me a voltage vs time graph? Frequency analysis does not help here.
regards Andrew T. |
#4 |
Pretend it is an active filter and calculate the frequency, remember both caps are charging at the same time.
Look at the DH500 circuit. It will pass 40V at 8hz, and trips at about 1.5V DC in about 100mS or so. The trip level is fine for hi-fi, but I changed them to 7.5V for PA use. |
#5 | |
Hi Djk,
how did you work this out Quote:
Of course it does, but how?
regards Andrew T. |
#6 | |
Try this, its very good and I find it very easy. |
#7 |
if you're going to use a free spice why not one without limits, used by pros who have budgets for the K$ packages:
http://www.linear.com/company/software.jsp LtSpice / SwcadIII is pretty good in absolute terms, insanely good for free |
| B+ time delay relay | cbutterworth | Tubes / Valves | 24 | 31st August 2011 12:53 PM |
| time delay with 2 amps? | thedman | Solid State | 2 | 2nd November 2007 12:22 PM |
| adjustable time delay | back | Analog Line Level | 18 | 1st March 2006 08:01 AM |
| subwoofer time delay | mart34 | Subwoofers | 14 | 15th August 2004 11:19 PM |
| Time delay without the $600+ expense?? | HobbesJunior | Parts | 7 | 15th November 2003 02:19 AM |
| Page generated in 0.08226 seconds (74.50% PHP - 25.50% MySQL) with 10 queries |
