Old 10th April 2006, 10:03 AM   #1
Send a message via MSN to Toast_Master
Default What makes a Power amp suitable?
Hey
what makes a power amp suitable for running a passive subwoofer?
Because I plan on buying the Biema Q series power amp that can bridge 1200 watts rms into 8 ohms
Im hoping just high power, because I feel its a bit of the bandwidth that matters because this amp does 1200 watts @10hz - 50Khz +/- 1.5 Db and cutting of the amp 80 hz is 625 times less than the bandwidth
Old 10th April 2006, 05:02 PM   #2
it is pretty much just power that is the only consideration.
/sreten.
Old 11th April 2006, 01:17 AM   #3
jcx is offline jcx  United States
Behringer europower 1500 may be cheaper
Old 11th April 2006, 03:22 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Any good driving capability amp will do the job.
Old 11th April 2006, 05:32 AM   #5
The sub is for no pacific purpose in general just for both music and home theater,
The cut offs are: (hopfully)
High pass 18hz 2nd order
Low pass 80hz 4th order
I want enough extension and low group delays in a moderate sized box...if I get low extension and low group delay it will be AWESOME for both music and home theatre, but for the price im going to pay it will defintly be good enough
Old 11th April 2006, 03:03 PM   #6
diyAudio Moderator Emeritus
I've got a similiar question. What kind of DIY design that suitable to drive 2000W/8ohm subwoofer (Skanning)? I just feel that making classAB is not wise.
Should it ONLY classD that suits this Skanning?
Old 11th April 2006, 03:23 PM   #7
mzzj is offline mzzj  Finland
I would go for triple-darlington output stage, dozen or two MJL-series transistors, possibly two channels bridged.
And something like this for heatsink...
Class-D is lot more difficult to design, especially at these power levels. Class-AB design is pretty much same no matter if it is 200W or 2000W design, but with Class-D you have completely new set of problems when you step up the power.
Suitable SE power amp Jamesuk1 Full Range 3 29th August 2008 11:00 PM
What makes a power amp fail... pflodin Solid State 38 1st August 2004 11:50 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 09:49 PM
Page generated in 0.09673 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
