Old 9th April 2006, 08:09 AM   #1
clem_o is offline clem_o  Philippines
Default Aurex SB-150
Hi!
Anyone have info on this integrated amp? The only thing I can manage to get from the web is that Aurex is (was?) Toshiba's high-end line.
A friend gave me the unit, the left and right channels "drift", sounding horribly underbiased or clipped, then later ok, then later clipped again. I have not confirmed if the problem happens to both channels at the same time.
Any info / data appreciated...
Cheers!
Clem
Old 9th April 2006, 03:39 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Clem,
The information you got is correct. Aurex was Toshiba's higher end audio line.
Wait until you here distortion and look at the output with a 'scope. Measure the bias current with speakers disconnected.
I don't have a diagram, sorry.
-Chris
Old 9th April 2006, 08:16 PM   #3
Default !
I had once Toshiba Aurex A-50 amplifier.it's not powerfull amplifier,only 2*30W 8ohm!
Pa mislim sta reci!
Old 10th April 2006, 12:34 AM   #4
Hi Chris,
Funny thing about it is it doesn't follow the usual crossover distortion sound pattern (i.e. as volume increases the distortion gets to be less audible). When it acts up, the distortion sounds about the same regardless of power level, leading me to think its more like an assymetric signal (thus some kind of saturation or cutoff problem). The output remains essentially DC-free though, the offset is around 4mV, pretty good!
Popped the lid off and gave it a cleaning. Its got a single-package diff-amp input and complementary outputs... promising but no exotic parts... I'll put a 'scope onto it sometime this week...
Clem
Old 10th April 2006, 12:37 AM   #5
Default Re: !
Hi Victor1986,
Yes, you're right, the trafo is very small; in fact the output transistors are TO-220, although the rails are +-35 volts. So I'd guess this SB-150 is rated even less, perhaps 20W/ch. If I manage to get it working I might use it in a small room, so I think the low power isn't an issue...
Clem
Old 10th April 2006, 12:41 AM   #6
anatech's Avatar
Hi Clem,
Show me what a sine wave looks like.
Please?
-Chris
Old 10th April 2006, 12:49 AM   #7
Default SB-150 - pics
Well, have a look at it, nice 1980s (?) integrated amp!
Cheers!
Old 10th April 2006, 12:50 AM   #8
Hi Chris,
The sinewave you're going to see is going to look ugly. Tek uses an 8-bit ADC.
Clem
Innards of the amp...
Old 10th April 2006, 01:27 AM   #9
anatech's Avatar
Hi Clem,
Bring on the nasty sine wave. It may have clues.
Man, I have fixed so many of those amps over the years. Whatever the model number is at the time, the amp stage remains the same.
Are you sure it's not in the preamp stage or a switch contact?
-Chris
Old 10th April 2006, 02:10 AM   #10
Hi Chris,
Nothing eliminated yet, I agree that the problem could be in the preamp, was going to 'scope the line drive to the amp as well. The switches - seem to be ok. Only one is a bit flakey, that's the loudness.
I'll see if I can get to scope it tonight.. :-)
Cheers!
Clem
Toshiba-Aurex SB-A50 amplifier schematic... viktor1986 Solid State 0 13th January 2006 07:10 PM
Aurex (Toshiba) SA-5000 Schematic? manxam Solid State 0 30th December 2003 03:21 AM
Page generated in 0.12380 seconds (78.83% PHP - 21.17% MySQL) with 11 queries
