Old 5th April 2006, 03:16 PM   #1
vuki is online now vuki  Croatia
vuki's Avatar
Default Simple 2 stage PP fet amplifier
I made simple 2 stage push-pull amplifier. It sounds quite nice and measurements are not so bad too.
More about it at http://www.moxtone.com/s2s.htm .
Old 5th April 2006, 04:01 PM   #2
hacknet is offline hacknet  Singapore
im surprised at how the jfets can drive the gate capacitance of the hexfets.
Old 5th April 2006, 04:52 PM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
yes there ought to be a driver stage in there somewhere. Also, wouldn't you want to drive the fets with a higher voltage PS than is on the drains for source follower to get rail to rail operation.
All the trouble I've ever been in started out as fun......
Old 5th April 2006, 05:36 PM   #4
vuki's Avatar
Please, take a closer look at the schematic and measurements.
That's not a source follower on output - output stage has voltage&current gain!
Old 5th April 2006, 06:40 PM   #5
darkfenriz's Avatar
Do you run output stage in class A ?
How is PSRR ?
Old 5th April 2006, 07:00 PM   #6
Voltage gain ? Really ?
Old 5th April 2006, 07:09 PM   #7
vuki's Avatar
@darkfenriz
Ic of output hexfets is 200mA
I don't know PSRR, but with 350mVpp at output PS there is only noise on speaker output and absolutely no hum&noise to be heard on 94dB/W/m sensitive Tannoys.
@Upupa Epops
Voltage gain. Really.
Old 5th April 2006, 07:15 PM   #8
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
sounds like you're trying to say this is a bit of a hafler transnova clone. my croatian is REALLY bad :-(
never seen it done without using lateral MOSFETs at output.
mlloyd1
Old 5th April 2006, 07:22 PM   #9
vuki's Avatar
@mlloyd
Yes, something like that. Jim Strickland is mentioned in the text as you have maybe seen. It works nice with hexfets, but maybe it would sound even better with lfets?
Old 5th April 2006, 07:22 PM   #10
moamps is offline moamps  Croatia
Some background reading:
http://www.tubecad.com/2004/blog0006.htm
Simple phono stage (MC) Onvinyl Analog Line Level 5 9th August 2008 09:50 PM
Simple 12v gain stage dublin78 Solid State 10 14th April 2008 03:37 PM
The NSSPS (Not So Simple Phono Stage) dsavitsk Analogue Source 10 15th November 2005 04:52 AM
simple BJT gain stage hihopes Solid State 2 22nd September 2005 08:19 AM
simple input stage for amp? AudioGeek Solid State 9 3rd September 2004 09:54 PM
Page generated in 0.12076 seconds (71.97% PHP - 28.03% MySQL) with 11 queries
