I want to make any cheap transistor amplifier.I look for any very simple amp with good sounding like the DoGC,but this amp from WidowMaker is very commercial.I look for may be 25-30 W @8 Ohms from mono block. May be the reply is under my nose,but I can`t find it,help me.
I have one GainClone,but I look for a little natural sounding. |
#2 |
there is a commercially manufactured audiophile hungarian amplifier, called Canopus. It can be easly modied. Better transistors, good passive components, etc... I think it's so simple. Regards, |
#3 | |
Bias trimmer is potential fire, but the amp is nice for simplicity |
#4 |
replace that BD139 Vbe mult. with a BD140(reverse emitter & collector of course) Maybe place 3 forward bias diodes from E to C of that BD140 to limit bias.
All the trouble I've ever been in started out as fun...... |
#5 |
i think the pot in the vbe mulitplier can swap places with the resistor to make it safer...
#6 |
Hungarian people don't make a short at output ?
#7 | |
If you would like a very natural and excellent sounding amplifier, that is also very affordable, then you should have a look at the Simple Killer Amp(SKA) by Greg Ball. Just have a look at the Simple Killer Amp Listening Thread and the Simple Killer Amp Constructor Thread. Also, have a look at his website (click on GURU) http://members.dodo.com.au/~gregball/guru_001.htm
KL. |
#8 |
You are all right about Vbe multiplier. When this amp is DIY-ed, than a safer Vbe mult. needed.
Spec's and other infos in the manufacturer page: In english: http://www.heedaudio.hu/en/prod_el.html Deutsch: http://www.heedaudio.hu/de/prod_el.html Magyarul: http://www.heedaudio.hu/hu/term_el.html There are several modified version of this amp. For example using simple darlington output instead of the CFP, improve PSRR with two diodes, resistors and elkos, etc... It's your choice to make it better. |
#9 |
the posted schematic is based on sziklai (compound follower) output stage. There are many warning that this is more difficult to set up. Maybe a more easily set up emitter follower pair would be better for a beginner. Yes, swap the pot for the lower resistor and up the resistor from 220r to 1k0.
regards Andrew T. |
#10 |
John Linsley Hood his amps?
I have build 2 monoblocks, has only 4 transistors/channel
Daisy Bell |
| Simple Circuit to Pull a Transistor to Ground? | EchoWars | Solid State | 3 | 23rd September 2008 04:42 PM |
| Simple and tested bipolar transistor amp | sekanix | Solid State | 41 | 19th June 2008 11:42 AM |
| i want to build a amp with 1-4 Transistor MAX!! -very simple | Dj BASS AMP | Solid State | 61 | 20th June 2005 01:10 PM |
| Need simple bipolar transistor pre amp | willy | Instruments and Amps | 3 | 19th December 2003 09:25 PM |
| Page generated in 0.14584 seconds (71.02% PHP - 28.98% MySQL) with 11 queries |
