resistor blow up !
resistor blow up !
Old 3rd April 2006, 08:47 AM   #1
Ahmad_tbp is offline Ahmad_tbp  United States
Default resistor blow up !
hi i have built this amp many ago :
http://www.ampslab.com/c200qc.htm
and use it in a guitar combo amp , it worked well till some days ago after a few hours of workin , its sound reduced and r22 burned up completely , but the whole amp work well ( not as before but not major change ) even after r22 burnin completly , i checked wires , cahnged the output transistors , changed the resistor w a higher wat , test it with diffrent speakers , but the problem still reamins , when i turn it on , after a few minutes the resistor start to burn , but not major change in quality of output sound , and all transistors and the psu working well and cold even while the resistor is burning ...
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 3rd April 2006, 08:52 AM   #2
edl is offline edl  Hungary
edl's Avatar
If the Zobel's resistor get's hot, or it burns, then your amp is oscillating.
Check the C7 Miller-cap, or even change it to 100pF.
Old 3rd April 2006, 02:34 PM   #3
thnxk , in fact i completely removed C7 before !
i mean from the start ! , lol
i wanted to solder it again but it seems i blowed up all the circuit by a bad mistake , the input wire clashed w collector of mj15016 ( i used mj15015/16 ) and after a big spark ! there s no sound come out of it !
lol !!!
i m tryin to fix it and use c7 again , is it possible that burnin of r22 was becuz of lack of c7 ?
cheers
Old 3rd April 2006, 06:01 PM   #4
edl's Avatar
That was a really irresponsible action!
Yes. R22's burning was caused by lack of C7.
So, let's solder a 47-100pF cap in place of C7! Your problem will be solved.
And always remember: in such amplifier topology Miller cap (here it's C7) is really necessary, never remove it!
Best regards,
Old 4th April 2006, 07:56 AM   #5
wohoo !!! .
thank u man ... didn t fix it yet but at sure it will work fine so
Redards .
Ahmad
resistor blow up !Hide this!Advertise here!
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 07:11 PM
Blow up once, Blow up twice and Blow up somemore S.C Chip Amps 14 6th March 2005 01:09 AM
Will This Blow Up? Trout Instruments and Amps 8 6th February 2005 01:52 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 04:18 AM
Will it blow up? dickerbeen Everything Else 1 17th April 2003 06:21 AM
Copyright ©1999-2017 diyAudio
