Hi, ive a working mic preamp however im wanting to alter the tone of the output by adjusting trebel and bass. I understand the principal behind the common 741 active trebel and bass circuits such as shown here http://www.antonine-education.co.uk/...ve_filters.htm
However is it possible to combine a trebel boost and bass boost filter on one output and swap the resistor value in each for a log potentiometer to vary the amount of trebel and bass, in essence to form a basic tone control? If so, linking the circuity in parallel should work? Thanks for any help |
#2 |
search on active baxandall tone controls. |
#3 |
hi thanks, the active versions look rather ideal, but for now im wanting something much simpler. Basically i want to link a high pass and low pass simple active filters and add relplace a resistor with a pot to allow me to alter the bass and trebel individually.
This should be possible? Thanks |
#4 |
Did it Himself
You can sort of do it, but I stress that you heed sreten's advice as it's the only way you are going to get the result you want. The Baxandall tone control is no more complicated than an active filter and recombination circuit.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 | ||
Why not use This instead? Straight from an elementary text on op-amps: uses but one op-amp (do replace the suggested op-amp with a really good one) provides both bass and treble cut/boost, and is a helluvalot simpler and easier to implement. |
#6 |
Did it Himself
Thanks basically the Baxandall system.
#7 |
#8 |
right thanks everybody im testing out all the varying options. One question though, take a standard bass boost active filter using a 741, 2.2K, 2.2M, 10K and 47Nf capacitor. It works fine, in that it boosts the bass frequencys a little however something is not quite right as powering the opamp makes no difference, therefore it seems to be working passively. Im using 9V pp3 batteries but i should have thought them to work fine?
Thanks |
#9 |
Did it Himself
If you post up the schematic you are using or even just link to it, that will help us diagnose the problem. Sounds like your breadboarding could be wrong though.
#10 |
well the bass boost, and trebel boost filters both work to an extent but passively not actively with the opamp. Here is the link to the site where I got the schematics from and ive attached the bass boost schematic.
Thanks |
| Active notch filters | neutron7 | Full Range | 2 | 19th November 2006 12:51 PM |
| Bob Pease on Active Filters | Speedskater | Solid State | 0 | 6th October 2006 11:24 PM |
| active filters: which resistors to buy | akunec | Chip Amps | 11 | 13th March 2005 02:09 PM |
| where to place active filters? | AndrewT | Multi-Way | 1 | 22nd October 2004 01:14 AM |
| Which op amps do you use for active filters?? | zx3chris | Parts | 4 | 25th April 2003 07:42 AM |
| Page generated in 0.09717 seconds (82.03% PHP - 17.97% MySQL) with 11 queries |
