Old 6th April 2006, 11:12 AM   #21
clem_o is offline clem_o  Philippines
Hi Andrew,
And despite that, we manage to blow up countless numbers at the Uni...
Cheers!!
Clem
Old 6th April 2006, 11:17 AM   #22
DD_Davo is offline DD_Davo  United Kingdom
aha right, ive moved the wire from pin 3 to the rail above i.e so it isnt really connected to anything. However i've still the same problem, adding a 9v battery doesnt have any effect. Infact i can unplug the opamp from the board (remove it) and theres no difference the audio signal is fed through and sounds slightly different as though its passively altered. hmmm i must have done something majorly wrong here
(ive 3 741's so hopefully i wont kill them all, and yes ive had them go up in smoke before but luckily no fire )
Old 6th April 2006, 11:55 AM   #23
ok following this:
Ive rebuilt the circuit as shown in the attached image the problem now, like ive incurred before is that theres loads of noise introduced into the circuit and the audio single is very crackly. This worsens when i power the opamp from a 9v battery. This should be simple too!
Old 6th April 2006, 11:58 AM   #24
Did it Himself
richie00boy's Avatar
No, not connected to anything is not what clem said. Connect it to ground. Read his post again, he even drew a simple wiring didagram for you and explained it clearly. ALL your grounds are wrong.
In fact you are lucky your power amp has a DC blocking cap at the input or your would have blown up your speakers.
In future I would also recommend you breadboard with +ve at the top and -ve at the bottom to make it easier to follow. And put chips so that the pins are like 1234, not backwards. But I see you have done this now with your last pic.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th April 2006, 12:04 PM   #25
yes i realised and i have done what he said but now theres the problem of introduced noise. I still cant understand the fact that powering the opamp makes no difference, i must have done something stupidly wrong since theres no amplifcation whatso ever to match the gain on the input.
Ok its de-amplyfying, by large amounts, some of the noise is from a poorly soldered 3.5mm connection so im sorting that but that unfortunately isn't going to solve the filter problem.. hmmm
Old 6th April 2006, 12:51 PM   #26
Hi DD_Davo,
If you haven't solved it in 12 hours I'll see if i can put something together and take a pic of it.
Cheers!!
Clem
ps: why 12 hours - sleep time here...
Hang on - one question: when you write "...a 9V battery..." you mean TWO 9V batteries, right? If not, well, there's the problem...
Old 6th April 2006, 01:27 PM   #27
Did it Himself
The schematic is also wrong, for bass boost. Everything except the 1k input resistor should be in the feedback loop.
Old 6th April 2006, 05:25 PM   #28
nope! a singular 9v battery, i was told it would work...
but thanks for your help everybody you'll be glad to know it works a treat now!
thanks again
Old 6th April 2006, 06:34 PM   #29
Did it Himself
You can make it work off a single battery, but not like you have arranged it.
Old 7th April 2006, 01:23 AM   #30
Congratulations! Enjoy!
Cheers
Clem
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Bob Pease on Active Filters Speedskater Solid State 0 6th October 2006 10:24 PM
active filters: which resistors to buy akunec Chip Amps 11 13th March 2005 01:09 PM
where to place active filters? AndrewT Multi-Way 1 22nd October 2004 12:14 AM
Which op amps do you use for active filters?? zx3chris Parts 4 25th April 2003 06:42 AM
Page generated in 0.10739 seconds (77.56% PHP - 22.44% MySQL) with 11 queries
