Hello all,
New to the group and I'm looking for any insight to a very strange problem. I drive a pair of B&W 801M's with a Mark Levinson No27. Latley the bass would drop out and only the mids and highs would play. I went through all my connections to the speakers checked the xover boards in the speakers and found nothing. Checked the line input cables to the amp - perfect. But if I pick up the front of the amp and tilt it the woofers come back on. This is very repeatable. I think there is a relay on the output to stop turn on transients. Could it be the relay? Or maybe a board is bending when the amp is picked up closing a short. Any ideas? Thanks |
#2 |
Hi dbev,
Welcome to DiyAudio! Your fault may be relay contacts, or an intermittent solder joint. Shorts generally cause smoke, flames and other depressing things to happen. If it isn't the relay, or if you are uncomfortable with this (electronics service), take in in to a good technician - not a cheap technician! They may be other things that could use attention. -Chris |
#3 |
Thanks Chris,
I'm ok with digging into it. I was just wondering if anyone else out there has run into this problem so I don't have look at everything. I alway did want to look inside her. Dave |
#4 |
Hi Dave,
A good tech. keeps an open mind until the fault is found. -Chris |
| mtx amp problem [[help!!]] | fuzzypinkhat45 | Car Audio | 3 | 8th July 2008 05:34 AM |
| I need help with a pot problem. | Harderror | Class D | 8 | 16th December 2006 04:04 PM |
| FRD/ZMA Problem | Twisted85 | Multi-Way | 5 | 4th December 2006 01:19 PM |
| p3a problem | MaXiZ | Solid State | 17 | 16th July 2005 07:14 AM |
| Page generated in 0.08098 seconds (72.80% PHP - 27.20% MySQL) with 10 queries |
