Old 30th March 2006, 01:46 PM   #1
Default Changing inputs and outputs on DH-200
Hey all. Some of you remember me with the DH-200 switch that went bad. You all helped me out GREATLY. Thanks!!
I have read though this WHOLE thread. WOW, what great info.
I want to change out my inputs and outputs on the amp. I want to go with maybe gold plated. Better than what the originals are. What do you all recomend? The originals are starting to corode.
I deal alot with www.partsexpress.com . Do you all know if anything from there would work? Somehting that would be a "drop in" fit?
Jake
Old 30th March 2006, 01:51 PM   #2
Ok. I picked up a gold plated panel mount phono jack from the Rat Shack. Didnt work.
Any help would be appreciated.
Also, after studying both left and right boards, I noticed that they were identical. So why is the right chanel input grounded through a resistor but the left grounded directly to the chassis?
I do appologize for the repeat in this thread (posting in DH-200 mods) But I figured there was so much going on in that thread that I didnt want to change the subject.
Old 30th March 2006, 09:59 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
it's for avoiding ground loop....
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 30th March 2006, 10:08 PM   #4
Using a new panel mount jack input. Is this resistor needed? In other words, does it have to be there, or can I hook both jacks the same way?
Old 30th March 2006, 10:28 PM   #5
Zen Mod's Avatar
leave that resistor in place;
or you can do it as I do it always:
isolate input jacks from case
solder piece of coax to each (hot on hot,gnd to gnd)
solder just live end on pcb,and insulate braid (screen) on that end
solder two pieces of thin insulated wire on central ground (central earth point -between two electrolytics) then route and solder one wire to one input jack's gnd and other wire to other input jack's gnd
What components has to be present on the balanced inputs/outputs of an audio ADC/DAC? skpb Analog Line Level 3 12th October 2006 07:30 PM
Please advise a 20- or 24-bit Audio Codec with Differential Inputs/Outputs. skpb Digital Source 2 9th January 2006 03:27 PM
designing inputs + outputs of electronic crossover stinkpot Parts 12 14th May 2005 05:07 PM
Buzz Noise on outputs with inputs attached akunec Chip Amps 3 7th March 2005 12:31 AM
Why are XLR outputs male, and inputs female? Bricolo Parts 5 30th August 2004 01:43 AM
Page generated in 0.20708 seconds (90.23% PHP - 9.77% MySQL) with 10 queries
