What is biwiring?
What is biwiring?
Old 30th March 2006, 10:43 AM   #1
anders.a is offline anders.a  Sweden
Default What is biwiring?
This biwiring is confusing stuff. What is he really talking about?
http://www.whathifi.com/newsMainTemp...ewssectionID=3
Is this really true or have I misunderstood something?
Old 30th March 2006, 10:54 AM   #2
lndm is offline lndm  Australia
The only argument I can buy (and IMO it's a stretch ) is that a single cable can reduce the damping factor of an amp. Interaction between the sections of crossover are 'locked' behind this reduction in damping factor. Running a separate wire from each section to the amp will therefore reduce unwanted crossover interaction.
I use an amp with a low damping factor, I don't bother with bi-wiring instead choosing to do something that will make a real difference.
Old 30th March 2006, 11:01 AM   #3
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
That's not very serious article. What are you particularly confused about?
Old 30th March 2006, 11:15 AM   #4
I started to get lost about here:
But we digress - back to the crossover. One of the problems with a standard crossover is that since one pair of cables carries the signal to and from the amp, bass signals can tend to swamp the more delicate treble stuff, especially in the return (or negative) connection back to the amp.
and
By separating the signal all the way back to amplifier's output stage, using two runs of cable or a purpose-made four conductor biwire cable, these effects can be greatly reduced. To do this, you need speakers designed for biwiring.
That means the crossover needs to be completely split, without the common negative found in standard design.
And
To all intents, a biwirable crossover is two separate circuits - one to filter the treble out of the signal for the bass driver, the other to prevent the bass from reaching the treble driver.
Old 30th March 2006, 11:19 AM   #5
darkfenriz's Avatar
Yes, these are most humouristic parts of article. Trust your own mind.
regards
P.S. reread first paragraph you've quoted.It purely violates current Kirchhoff's law. You should have quit reading there.
Old 30th March 2006, 12:48 PM   #6
BobEllis is offline BobEllis  United States
BobEllis's Avatar
biwiring: (verb) the act of selling an extra set of overpriced speaker cables to the naive consumer, usually resulting in a nice bonus for the salesman.
Old 30th March 2006, 12:56 PM   #7
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
Biwiring really shud be spelled "buywiring". It is just another snake oil, faith based concept turned product designed to separate the gullible consumer from his cash.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 30th March 2006, 02:14 PM   #8
poobah is offline poobah  United States
poobah's Avatar
"buywiring",
Good one Bob!
Old 30th March 2006, 02:19 PM   #9
phn is offline phn  Sweden
phn's Avatar
It's either that or single-pair binding posts Dynaudio doesn't know loudspeakers.
Old 30th March 2006, 02:24 PM   #10
Bas Horneman is online now Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
How about this guys. I've never felt the need to "buywire"..but I guess having a crossover next to your amplifier and then running a pair to your tweeter and then a pair to your woofer ( in the case of a 2 way) should have advantages?
If you can see the speaker cone move...it's not hifi.
What is biwiring?Hide this!Advertise here!
Biwiring cable suzyj Solid State 6 5th April 2008 12:44 AM
I have a question about the biwiring.. haggy Multi-Way 69 24th April 2007 06:30 PM
Impedance, Power and BiWiring VintageWS Multi-Way 1 7th February 2007 05:36 PM
T-amp stealth mod in passive biwiring Mr.Mekulic Class D 6 28th June 2006 09:25 PM
Dynaudio Contour and biwiring? seppstefano Multi-Way 3 16th January 2004 04:07 PM
Copyright ©1999-2017 diyAudio
