QSC MX3000a schematic. Anyone? - diyAudio
Old 29th March 2006, 02:43 PM   #1
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default QSC MX3000a schematic. Anyone?
Anyone happen to have a schematic of a QSC MX3000a?
The amp 'should' be fixed for the weekend so there is hardly time left to order it.
/Hugo
Old 31st March 2006, 06:27 AM   #2
deflorator's Avatar
Send a message via ICQ to deflorator
Default schematics
I have 3 pages from service manual with schematics
Please, contact me by e-mail
vsevolod.martsenyuk[[[@]]]raffsoftware.com
Please, remove [[[ and ]]] before mailing
I hate spam.
mx3000aa jpg„*714574
mx3000ab jpg„*338408
mx3000ac jpg„*343374
Old 31st March 2006, 06:37 AM   #3
Workhorse's Avatar
Hey HUGO,
Check this out:
http://www.qscaudio.com/support/libr...ms/mx3000a.zip
K a n w a r
Old 31st March 2006, 07:44 PM   #4
Netlist's Avatar
Thanks a lot to both of you. Meanwhile I was able to find the service manual as well.
/Hugo
Old 30th September 2015, 11:10 PM   #5
I'm having a problem with a QSC MX3000A with a DC offset voltage on the - rail . Its reading -72 volts that's a DC offset of 32 volts as the rails should read -+44 volts respectively . I found a zenor in the circuit that may be the problem but I checked it and it checked good altho still could be bad as I have seen that problem before., There is also a voltage regulator in there as well. So ether or both could be culprit. If anyone has any info of what may be the cause....Please let me know . The problem is on that board as I turned the A&B ch boards over and the problem moved from ch B to ch A.
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
Need bat vk-200 schematic krezov Solid State 1 24th January 2008 08:05 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
SVP-PRO schematic surfer156 Tubes / Valves 3 17th July 2007 02:28 PM
Copyright ©1999-2017 diyAudio
