Quad 44 preamp no sound in left side
Whe you say 'mono', do you mean you select mono mode on your preamp with a front-panel switch?
If both channels work that way, it is clearly not the power amplifier at fault.
It is probably something in the switching or early stages of your preamp, but signal tracing with a scope or meter is going to have to be done to isolate it.
Administrator
Joined 2004
Hi jollyrogernl,
Arrr matey! There be bad solder joints on the main PCB in the 44. Resolder all the leads from one side of the board to the other. There may be other issues but I can't remember all of the service note off hand.
-Chris :Pirate:
