Electrocompaniet AW65 Help request
Old 28th March 2006, 10:39 AM   #1
rollo22 is offline rollo22
Default Electrocompaniet AW65 Help request
Hello all
Could anyone, please, give me some clarity on this issue ?
The schematics is for the Input Stage only of the AW65.
Power Supply is -+47Volts.
The offset measured at OUT drifts with temperature from - 10Volts to +3Volt after 2 minutes.
The temp of Q8-Q9 reaches 63ºC.
The calculated current on Q9 (Vce 36V) collector is 23mA for a dissipation of 800 mW.
Does it all make sense ?
I have doubts that the offset should drift so much.
I heard that Electrocompaniet amps dissipate a lot of heat, maybe that's why the fault on this amp destroyed so many transistors, they work at such Hi Temp.
Many Thanks
Rollo
Old 28th March 2006, 11:04 AM   #2
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Hi Rollo,
IIRC the AW65 has a separate protection-servo board.
Do you have a photo of your unit?
I once have fixed a wannabe-AW65 (but more likely a mixup between different EC models)
Ciao
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 28th March 2006, 02:45 PM   #3
Here it is
Please tell me all the dilfferences you see.
I think the big blue caps are not original.
There are some Transistors missing for now.
Ciao
Old 28th March 2006, 02:58 PM   #4
Andypairo's Avatar
you can check the one I have here http://www.diyaudio.com/forums/showt...=&pagenumber=2
Btw you seem to miss the protection / servo boards... the photos I made show that these are marked "AW-65"... let me guess... does your amp come from a "official" EC repairer in Meda?
If so both you and my friend (the owner of the amp) have ben screwed by the same guy....
Cheers
Andrea
Old 28th March 2006, 04:08 PM   #5
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Q8 should be NPN
Old 28th March 2006, 04:31 PM   #6
Hi
there is a marking AW behind the finals and pp on lower right.
No, I bought it from a guy in Switzerland.
Have you got a photo of the servo board with connections to the amp board ?
even if you made it.
Rollo
Old 28th March 2006, 04:32 PM   #7
and this
Old 28th March 2006, 04:33 PM   #8
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I suppose the original MT200 Toshiba output devices are blown too ?
The original electrolytics were Roedersteins, these looke like Philips or Sprague.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th March 2006, 04:36 PM   #9
Yes it is the same as Q9, my mistake (the model is the same though).
as and finally...
Old 28th March 2006, 04:53 PM   #10
Here's the right drawing, I hope...
Rollo
Electrocompaniet AW65 Help requestHide this!Advertise here!
Electrocompaniet Help Andypairo Solid State 72 3rd December 2015 03:25 PM
Electrocompaniet ECI-4??? kimschips Solid State 18 4th February 2015 03:46 AM
Electrocompaniet aw65 transistors substitutes rollo22 Solid State 7 2nd February 2006 06:14 PM
Electrocompaniet AW 250 AMP. hogue Solid State 1 1st March 2004 05:48 AM
