Audio research voltage conversion
Old 27th March 2006, 08:31 AM   #1
jouch is offline jouch  Sweden
Default Audio research voltage conversion
I'm wondering if voltage conversion could easly be done on an ARC D-130. The conversion is from 110v to 220.
Christopher
Old 27th March 2006, 04:16 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Christopher,
This unit may have a single voltage winding. If so, a step down transformer should do it for you. Size it larger than the amplifier's requirements by 50% so it runs cooler. Take care to measure the 120V side to make sure the voltage is not too high.
-Chris
Old 28th March 2006, 01:24 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
or get yourself a new transformer,but may void the warranty.
Old 1st April 2006, 04:59 PM   #4
commsysman is offline commsysman  United States
Try faxing an inquiry to Audio Research. Many of those amps have a power transformer that can be used on either 240V or 120V by reconnecting the power transformer leads in a different configuration. If that is not possible on your unit, they may be able to sell you a replacement transformer for your voltage and this would be nicer and not neccessarily more expensive than an external transformer.
767-577-0323 is the fax number at Audio Research.
Audio research voltage conversionHide this!Advertise here!
Voltage conversion; need help please steve96822 Power Supplies 12 8th September 2006 07:45 AM
voltage conversion for krell audio video standard james559 Solid State 0 17th February 2005 07:17 AM
Voltage conversion? mmx_2 Solid State 0 28th December 2004 12:25 PM
Voltage conversion: US to UK? diaspora Parts 3 3rd May 2004 08:09 PM
voltage conversion mike moore Everything Else 4 10th February 2001 07:43 AM
