Separating Transformer and Caps from Int Amp
Old 27th March 2006, 06:24 AM   #1
kptseng is offline kptseng  Singapore
Default Separating Transformer and Caps from Int Amp
Hi All,
I've been wanting to upgrade the parts of my Onix OA21 integrated amp for a where, but face with serious space constrain with the small box.
One option is to move the trabsformer and power supplu caps to a separate box and link to the amp board with ~0.5m cables.
Few things I wanted to do are:
1. Better power caps.
2. Better volume pot - looking at the Alps Black but no space.
3. Adding better voltage regulator.
Any detrimental effect if I do this?
I thought of the soap concept which adds additional transformer and bigger caps in a separate box, but somehow I found the soap kills the music.
Old 28th March 2006, 01:26 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
What's the rating of the transformer and caps???
Old 28th March 2006, 05:44 AM   #3
I think transformer is at 350VA 25V; Caps are now 4,700uF 63v.
My main restrcition is space within the box. By mounting the transformer and caps in a separate box I intent to put in 6,300uF BC114 and bypass with good 10uF film caps.
Also with the transformer and caps out of the existing box I have room to upgrade the current ALPS blue to black, also possibility in putting in better voltage regulators.
My main concern is really if there is any side effects in mounting the transformer and power caps in a location further away (about 0.5m).
Old 28th March 2006, 06:37 AM   #4
lndm is offline lndm  Australia
Probably no problem but if you are concerned, you can shield the supply rail cables and consider caps at the amp end.
Separating Transformer and Caps from Int AmpHide this!Advertise here!
Separating bonded glass mmerig Everything Else 14 19th March 2008 01:27 PM
separating PSU for preamp woodturner-fran Tubes / Valves 4 7th February 2008 10:28 PM
caps for transformer.... Dj BASS AMP Solid State 4 27th July 2003 09:27 PM
DIY Transformer + Caps Myren Parts 9 22nd March 2003 12:12 PM
question on transformer and caps JAZZ2250 Solid State 6 3rd August 2002 07:58 AM
