Class A(Transistor) V Gainclone Debate
Old 22nd March 2006, 12:49 AM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Lightbulb Class A(Transistor) V Gainclone Debate
Hi everyone,I want to build a new Amplifier but am hopeless at making my mind up.I keep going round in circles.I made a Class A Emitter follower using TIP 141 bipolars and it was amazing,I had to keep it cool with an office fan.I'm using a chip amp from a pair of Sony PC speakers,nothing special,and it says 7watts max on the label.And yet such a small amp sounds amazing as well, driving my Goodmans Magnum K2,which are rated 50w @ 4 ohms with a 12" Bass driver.And sounds better than my JVC A-X2 @ 90w and my Technics SU V2 @ 120w.The JVC a Super A,fancy name,and with Transistors.The Technics had STK blocks and both units and are dead.
It seems as though my speakers prefer less power,making a Class A or a Chip amp ideal,especially Class A,because of heatsink size and cost.
I have a Toroid Transformer rated @ 2 x 40 volts and 5 amps each.This I would use in the power supply because it was expensive,and I have 4 x 8600uf caps from the above amplifiers,so what should I build around this supply?
Class A ? Gain clone ?
Thanks,Mikee55
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 22nd March 2006, 01:07 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Re: Class A(Transistor) V Gainclone Debate
Thanks,Mikee55
40v ac thats to much. I don't think your building a class a amp.
Old 22nd March 2006, 01:27 AM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Well, if that 40V is unrectified it is a bit too much for a GC as well. That voltage rating with that current is only really useful for a Class A/B amp, but there are plenty of good ones around, have a look in SS for SKA, AKSA etc...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 22nd March 2006, 12:16 PM   #4
that 40Vac 400Va transformer would suit ClassAB power amp upto about 250W to 300W total output.
A 2channel GB150 SKA driving 140W into 8ohms falls right into this category.
There are many other candidates producing similar outputs.
A single channel 250W into 4ohms is another option (using all you caps) but may not suit your stereo requirement.
For good (or better) bass performance you will need to increase your smoothing capacitance. A target of about +-12mF/channel should suffice for 8ohm speakers and double this for 4ohm.
regards Andrew T.
Old 22nd March 2006, 12:55 PM   #5
mikee55's Avatar
Default Thankyou
for your thoughts.
Hi all,thankyou,erm,could I use Regulation to bring the voltage down?Might seem like a waste of power,but it would save me buying another transformer!
Thankyou.Mikee55
Old 22nd March 2006, 01:43 PM   #6
grrr is offline grrr  Netherlands
Default do not regulate down
look at zen lite from pass that uses a high voltage. you do not have to use a current source because you can use a higher impedance resistor (or lamp) as load .
http://www.passdiy.com/projects/zenlite1.htm
you can make a 40v+ somthing powersuply and for example a class a amp that has a idle current of 1A than use a 30 ohm resistor as load.
Class A(Transistor) V Gainclone DebateHide this!Advertise here!
Class A, push pull amp using transistor space2000 Solid State 18 7th August 2008 03:53 PM
Class AB Super Symetry use Bipolar transistor Rembulan Pass Labs 9 4th October 2007 03:52 PM
Help! 50w Class A or 150w Class AB debate Toobstheway Solid State 12 17th September 2007 08:05 PM
best buffer gainclone transistor need tadiam Chip Amps 3 28th August 2007 02:02 PM
Self Class G. Transistor matching? subculture Solid State 4 31st May 2005 03:55 AM
