Old 20th March 2006, 08:52 PM   #1
adlaic is offline adlaic  United States
Default How to test bias
What is the bias and how do you test it on a transistor amp?
Thank You,
Adlai
Old 20th March 2006, 09:36 PM   #2
darkfenriz's Avatar
You can measure idle current of output devices by measuring voltage drop on emitter/source resistors (>95% of amps have them) when no signal is applied to input. Every digital voltmeter can do this.
Old 20th March 2006, 09:40 PM   #3
lgreen is offline lgreen  United States
lgreen's Avatar
we are not as smart as you, does this relate to bias? how so?
If I measure 1V drop across 0.5 ohm resistor, do you simply say V=IR and I = V/R so bias = 1/0.5= 2 amps per device. Then multiply by the # of devices to get bias/channel? Then multiply by # channels to get bias/ amp?
My DIY audio projects- PartTimeProjects.com.
Old 20th March 2006, 10:16 PM   #4
darkfenriz's Avatar
Yes, that's how I understand it, except idle current is the same through a pair of output devices.
Old 20th March 2006, 10:38 PM   #5
cpemma is offline cpemma  United Kingdom
Default Re: How to test bias
For what bias is/does, see this guide.
On the actual setting procedure, I found it slightly misleading in places, "Then, turn the amp off if you have only one set of speaker binding posts, or turn on Speakers B, and measure the DC offset." I'd just turn the volume right down, switching the amp power off seems a bit counter-productive.
If you can find a Service Manual for your amp it will advise on the manufacturer's recommended setting (and the test points to use).
Old 20th March 2006, 11:19 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
Yes. There are some general rules that experience will teach you. Also, when you have multiple output pairs, make sure the current is shared relatively evenly. That's an indicator of transistor matching.
-Chris
Old 20th March 2006, 11:30 PM   #7
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: Re: How to test bias
snake oil....
just another "expert" article,from series of "how to make that sheeety amp little less sheeety".......
I agree with you about manual- in any case manual is good for knowing exact procedure
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Page generated in 0.08879 seconds (78.25% PHP - 21.75% MySQL) with 10 queries
