Old 20th March 2006, 12:49 PM   #1
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Default Patriot V100
This amplifier was built by a Danish called Lars Clausen.
Same man has started(I think) LC Audio in Denmark.
I got hold of one of his amplifiers but it has a small failure before i will start using it in my HiFi-system.
It comes a small "Whistle" in right speaker but dissapears if i turn volume up shortly.
I do need Service Manual to investigate futher, or if anyone has experienced same failure.
ManUtd.
Old 20th March 2006, 10:41 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Lars is a regular visitor to this forum I believe, though these days he mostly hangs out in the class D section . Perhaps he will help you
/U.
Old 21st March 2006, 09:05 PM   #3
Hello ManUtd!!
- Hopefully you are the Dude i've been mailing with today, your real name is Bjørn, right???
Good luck with it, it is a VERY good amp, the only reason the production was halted was due to problems with the Aluminium precision from the machine shop!!!
- What did it cost you???
Lars / Viborg - Tech Support for LC Audio
Old 22nd March 2006, 08:12 AM   #4
ManUtd's Avatar
Default Patriot
Originally posted by nillerviborg
Hello ManUtd!!
You`re guessing is correct Lars and name too.
I got it for 5000Nok(As described with wistle),what do You think?
You probably think i am crazy? (I am,he-he)
Hopefully it is only Offset/Bias adjustment.
The model is a MKII with Sanken transistors inside.
Do You know the production Years for this model?
Reg,
Bjørn
Old 30th March 2006, 08:48 PM   #5
Default Re: Patriot
Reg,
Bjørn
GOD DAMMIT!!!
- In denmark thet goes sometimes for prices higher than the org. price of 20.000Dkr... - i have seen them sold for up against 28.000Dkr!!!
Very F... Cheap!!!
Production should be around 1998 or so, i'll check tomorrow to see if i have anything on them...
Old 30th March 2006, 09:11 PM   #6
ManUtd's Avatar
Default Re: Re: Patriot
GOD DAMMIT!!!
Very F... Cheap!!!
WoW Thats good news!
I will wait for Your reply.Lars.
I have short with time these days,but i think i will take it out of box this weekend.1 channel is working perfect the other one is
distorted in higher frequenz.I had a look inside last week and i sow a brown/Burned resistor.
I am very curious about sound on thisone.
regards,
Bjorn
Old 2nd April 2006, 11:38 AM   #7
- Hey ManUtd... - You could mail a picture or two for me at the company mail used previously!! - Maybe i can do some guessing!!
There is very sedom other faults than bad Potmeters in theese amps, as dscribed before!!
I have one myself, though in another cabinet... Play's very well, though!!!
Sincerely, Lars / Viborg - Tech Support for LC Audio
Page generated in 0.08646 seconds (78.33% PHP - 21.67% MySQL) with 9 queries
