Amplifier Problem !!!
Old 14th November 2002, 10:52 PM   #11
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
D.J.-
Is this the amp we worked out in another thread that was actually only about 150W?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 15th November 2002, 12:01 AM   #12
kevin gilmore is offline kevin gilmore  United States
Lets see, a 150 watt amp clipping its brains out into
2 x 4 ohm speakers in parallel. i.e. 2 ohms.
Keep fire extinguisher handy...
Reading all of this persons other posts it is obvious that
he is still searching for a free lunch.
Get a carvin or mackee or other real sound reinforcement
amp. Better yet, get a digital amp and it will run cool.
Or build my uber amp which is a measley 800 watts rms
per channel into 8 ohms. Slight little detail, weighs 350 lbs
plus the water chiller.
http://gilmore.chem.northwestern.edu/heatsink.jpg
cooled by this
http://gilmore.chem.northwestern.edu/chiller.jpg
and filled with this
http://gilmore.chem.northwestern.edu/heavywater.jpg
Old 15th November 2002, 08:39 AM   #13
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
the amp is 800W RMS made in israel...
the speakers is 900W RMS ~ 4 Ohm...
I t test the temperature with thermometer... - 55 c +/-
soo... thanks all for help...
Old 15th November 2002, 10:48 AM   #14
trwh is offline trwh  United Kingdom
trwh's Avatar
"if my amp at around 45 - 65 degrees C heatsink temperature...
it is ok?..."
This should be fine - as long as this temperature is stable, i.e. not slowly climbing.
"if the amp will shut down it is dont good !"
Yup. As you have seen I am not the only one recommending a good quality PA amp as opposed to a "DJ" amplifier
See ya,
Tim.
Old 15th November 2002, 01:12 PM   #15
buy yourself a pair of these
http://www.tripath.com/0105_eboard.htm
bridge each for mono, add two power transformers
and a couple of power caps and get 1500 watts rms
per channel.
cheap and effective. runs stone cold.
Amplifier Problem !!!Hide this!Advertise here!
problem with my amplifier marcojhp Solid State 3 24th January 2007 08:34 PM
sub amplifier problem testarossa2k Subwoofers 4 25th August 2006 06:36 PM
RF Amplifier Problem xitronics Solid State 9 15th April 2006 05:48 PM
Problem with guitar amplifier wiseco16 Instruments and Amps 5 21st September 2004 11:28 PM
Amplifier problem empire Parts 0 4th April 2003 09:43 AM
Copyright ©1999-2017 diyAudio
