Before I really got into DIY audio and gained more knowledge about it, I saw a website shouting the pros of current amplifiers. I have not re-read the site, now I have more understanding but was wondering if there really any advantages to current amplifers? What are your views? Edit: I forgot to leave the URL...Here it is: Current Amplifers Thanks, Gaz |
#2 |
On Hiatus
Thanks Rarkov for the Link, it was new to me.
I will have look at what Gary Novak has to give. |
#3 |
On Hiatus
this is what he uses
#4 |
It should be clear that this is a voltage amplifier, because of the 100% local feedback in the output stage. Gain should be close to 1.
Whether there is any advantage in current-drive of speakers has been discussed elsewhere on this board. But since this guy apparently doesn't know the difference between voltage and current amps anyway, I wonder about the usefullness of the rest of his arguments. Jan Didden |
#5 |
I wasn't able to find the thread you mention. Did it spawn off another topic as they so often do?!
![]() Thanks, Gaz |
#7 |
"But since this guy apparently doesn't know the difference between voltage and current amps anyway"
It looks like a current amplifier to me, in the sense that the output current will be some multiple of the input current. In the same way that a BJT is a current amplifier. I think what you are saying is that the input Z is all over the place. If this circuit were driven by a high Z current source then it would behave like a current amp. On the subject of whether it matters whether it is best to control the output voltage to the speaker or output current, it is obvious the voltage must be controlled because of the way speakers are designed. Driving a speaker with a current proportional to the input voltage will not sound right. I know, I've done it. |
#8 |
diyAudio Moderator Emeritus
Jan, Gaz,
This is, I think, the thread Jan is referring to. Unfortunately it is a bit Gromanized. That’s how it went from damping factor to output drive topologies. You can take a look if you want. info on amplifier damping factor Have fun, Rodd Yamashita |
#9 | |
The output current is definitely NOT related to the input current in any way, but is only dependent on the load (and input voltage of course). Again, this is the definition of a voltage source. The input Z is not all over the place, but is reasonably independent of the load. Vo=Vi means there is 100% feedback, so all the transistor gains are used to make the output voltage independent of the load -> voltage source. With a fixed input voltage, the output current will be whatever is necessary to maintain the same voltage at the output. I don't see by what stretch of the imagination one could call this a current source. Jan Didden PS Someone above used the term "current buffer", which of course it is. But the designer specifically talked about "current drive of speakers", and that cannot be done with this circuit. |
| Current Driven Loudspeakers and Tranconductance Amplifiers | Tube_Dude | Multi-Way | 263 | 24th November 2010 07:21 PM |
| Novel? current feedback technique for Class D amplifiers | Rhesus | Class D | 4 | 1st March 2004 07:02 AM |
| need help ! my amplifiers draw alot of current. | Dj BASS AMP | Car Audio | 6 | 1st December 2003 08:53 PM |
| Current Feedback Amplifiers Seminar | PGW | Parts | 0 | 7th September 2003 08:18 PM |
| Current feedback in class A amplifiers | marco | Solid State | 3 | 26th September 2001 04:19 PM |
