Old 19th March 2006, 08:40 PM   #1
MrGeebs is offline MrGeebs  United States
Default Noob Questions...
Hi Folks,
Please forgive my noobness, but I have no knowledge of the things you all do... so please be patient
I bought a new sound card, which has upgradeable OPAMPS.
This new sound card has a very low mic input level even with the +20db gain enabled.
The sound card supposedly has 2 OPAMPS for the mic input.
I was wondering if you guys could tell me if you think upgrading the OPAMPS might increase the mic level to a more acceptable setting?
The makers suggests using OPA2604AP, or OPA2134AP...
I honestly dont know which is better, nor can I even seem to find a place that would sell me just 5 or 6 of them...
So again folks, please tolerate my noob questions, and feel free to share any advice or experience you may have I will most certainly appreciate it
Old 20th March 2006, 12:28 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Low input level problem is related to OPAMP gain setting,not just the quality of the OPAMP itself.
Old 20th March 2006, 12:48 AM   #3
darkfenriz's Avatar
opamp's gain is defined by passive components, most often resistors. A change of one resistor will do the difference. Change opamp if you want lower noise and/or distortion.
Old 20th March 2006, 06:24 AM   #4
hey, thanks for replying
I wish to improve my mics input level, so will upgrading the OPAMP acheive this result?
I have no soldering skills, so cahnging stuff on the PCB is out of the question.
The manufacturer says you can improve the cards performance by upgrading the OPAMPS..
Can someone tell me what the difference is between the two I listed above? Is one manufacturer better than another?
Here is alink to the product if it helps...http://www.auzentech.com/products_xplosion.html
Thanks again...
Old 20th March 2006, 06:45 AM   #5
if you select your opamp carefully you should be able to improve both the noise and distortion performance.
You will need some data on your mic and on your circuit to be able to make that selection.
You cannot change the gain unless you are prepared to investigate the gain components around the opamp and change at least one of them.
regards Andrew T.
Old 21st March 2006, 07:59 PM   #6
infinia is offline infinia  United States
infinia's Avatar
Investigate your mic and connections (buy a new cheap mic to test $5) before trashing exp. sound card.
Most probably a software setting
microsoft panel> options>properties>recording>ok>microphone>advance d
try it let us know when its fixed.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 22nd March 2006, 10:48 AM   #7
DRC is offline DRC  United Kingdom
DRC's Avatar
Do you have the correct type / impedance microphone for you soundcard ?
For example, if you use a 600ohm microphone into a 47kohm input you will get a very low ouput.
Old 24th March 2006, 03:17 AM   #8
myhrrhleine's Avatar
Changing the op-amps will change sound quality, but not amplification of the op-amps.
The op-amps have an amplification of about a million times.
Most of it is thrown away in 'feedback' which makes the op-amp more linear.
Gain is set by the ratio of feedback resistor to the resistor to ground.
Typically 1+(R feedback/R ground)
noob with questions bdiddy876 Car Audio 2 27th March 2007 06:14 AM
Yet Another Set of Noob GC Questions Thomo Chip Amps 2 23rd February 2007 12:10 PM
Noob with questions... Tristanc1 Chip Amps 6 23rd September 2006 10:17 PM
Noob questions deriver23 Car Audio 1 25th August 2006 11:06 PM
Page generated in 0.09305 seconds (78.97% PHP - 21.03% MySQL) with 10 queries
