Old 18th March 2006, 08:15 AM   #1
Send a message via Yahoo to my89_928gt
Default speaker ohms to low
I have some surond speakers that I was going to run a second set of surounds(not 7.1 though doing that also).
But, to run the suround A and suround B the speaker loads have to be a min of 12 ohms each. They are 8 ohms
Is it possable to raise the ohm value of the speakers(say by adding a 4 ohm metal film resistor in series with the speaker wire)
All my speakers are MB Quarts except the sub.
Thanks for any thoughts,
Richard
Old 18th March 2006, 08:41 AM   #2
you could try adding a 3r9 resistor to each speaker and listen to the effect.
That series resistor will affect the damping (Q) of the speaker with the result that the bass will sound completely different.
You will need a power resistor to be able to dissipate the heat during loud music sessions. Try ten parallel 39r 600mW giving 6W capacity.
regards Andrew T.
Old 18th March 2006, 10:37 AM   #3
Bazukaz is online now Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I see no reason why a wirewound cannot be used here.Its inductance will be very small , compared to speaker's. These are often used in passive crossovers.
Lukas.
Old 18th March 2006, 06:25 PM   #4
myhrrhleine's Avatar
Personally, I wouldn't worry about the impedence and simply play them at slightly less than maximum volume level.
Old 19th March 2006, 01:21 AM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I agree with myhrrhleine and use them as is.
I had a set of rears that went down to 3R8 on a HT receiver that recommended 6R minimum. No problems and as long as you aren't driving to crazy levels it should be cool.
No longer DIY active
Old 20th March 2006, 01:36 PM   #6
I think I will see how much warmer it runs. If it dose not seem to get much warmer then I will not worry about it. Other than maybe putting a small fan on it to make sure it stays cool.
Thanks guys,
Richard
Old 20th March 2006, 01:42 PM   #7
the loading seems to stem from 6ohm minimum and two sets in parallel.
So ignore the surround B connections and wire the two L and
two R speakers in series if you are concerned about loading.
The series resistor idea will tonally unbalance the speakers.
/sreten.
Help: 4 ohms speaker with 6 ohm receiver honfatboy Solid State 4 25th August 2006 10:39 PM
T amp + 16 ohms speaker? Sushii Class D 8 7th July 2005 10:00 AM
Speaker Is 4 ohms, However........... OMNIFEX Multi-Way 11 27th January 2004 05:12 PM
speaker ohms jeff Everything Else 1 1st March 2001 10:05 AM
Page generated in 0.09036 seconds (75.60% PHP - 24.40% MySQL) with 10 queries
