Quality phono preamp ? - diyAudio
Old 14th November 2002, 12:01 AM   #1
Optical is offline Optical  New Zealand
Default Quality phono preamp ?
Im after a quality phono preamp (maybe audiophile worthy) to use in a mixing desk..
Does anybody have any experiance with one they have tried and found to be good?
Old 14th November 2002, 12:17 AM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default peranders - knows a lot about this
peranders have built an extreme phono amp
see his homepage
you do not need to build so advanced
there are good RIAA phono amps
using only one OPamp
here is a thread about phono amp peranders started
Really, really extreme phono, more extreme than mine
Old 14th November 2002, 12:25 AM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Do a search on "Pearl" or "Ono". Both are very fine phono stages . Here are some opinions: Pearl Phono Stage
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th November 2002, 12:26 AM   #4
oops i should elaborate, i need schematics..
soem feedback one ones you have tried out would be cool too
Old 14th November 2002, 12:36 AM   #5
Pearl schematic is here: http://www.passdiy.com/preamps.htm
www.audiosector.com
Old 14th November 2002, 08:59 PM   #6
Nicke is offline Nicke  Sweden
Nicke's Avatar
Why not try this:
It is based on the phono preamp made by Thorsten Loesh and the original could be found at his homepage.
It sounds pretty good...
Thorstens homepage
[IMG]My version of a phono preamp[/IMG]
Nicke
Old 15th November 2002, 06:28 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
soem feedback one ones you have tried out would be cool too.
If you want a basic circuit, you have lot's of them. I have made a couple of Excel files for calcuclating the RIAA network. Drop me a note if you or somebody else want those.
With risk for a will only mention in that I have got pcb's for a modest RIAA amp..... The amp is based on http://www.linear.com/prod/datasheet.html?datasheet=202
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 15th November 2002, 08:44 AM   #8
On Hiatus
WHERE would we all be without LT - Linear Technology
Old 15th November 2002, 08:56 AM   #9
Default Alaskan built phono preamp
Perhaps I can suggest one of my RIAA phono pre-amps. Its a great unit and is quite easy to build. Very low noise and offers adjustable RIAA equalization to optimize any cartrige. Each circuit board is for one channel.
Picture here:
http://www.audioamps.com/diyprojects...0301A-RIAA.htm
and another here:
http://www.audioamps.com/diyprojects...0301B-RIAA.htm
Some more info here:
http://www.audioamps.com/diyprojects.../0301RIAA2.htm
This preamp is also suitable for use in recording studios and can drive balanced 600 ohm lines. The NAB reproduce amplifier version has been used to replace stock reproduce amplifiers for the purpose of remastering old analog tapes to digital format.
I have not had enough free time to update my web site so some information is somewhat out of date.
John Fassotte
Alaskan Audio
Old 15th November 2002, 09:22 AM   #10
peranders's Avatar
Default Re: Alaskan built phono preamp
Pcb's looks very nice. Compare the link of Coph Nia MC amp when we talk about appearance.
Coph Nia MC Amp from Sweden
Interesting "star" concept of the layout.
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
High Quality Mic Preamp? sopapo Solid State 7 13th October 2005 03:36 AM
MC phono preamp Vortex Tubes / Valves 29 29th March 2004 10:39 AM
IC High Quality Mic Preamp xanduy Chip Amps 0 17th March 2004 05:54 PM
Copyright ©1999-2017 diyAudio
