#51 |
Well the new switch came in. Soldered all the wires in place......Plugged it in.....Flipped the switch...SPARKS flew everywhere!!....Plug caught on fire and fire was spreading....
Just kidding... switch worked perfectly. Plugged it in, flipped the switch on and the little red light in the switch lit up. Just like brand new. I unhooked the plate amp in both the MTX and the Polk. Ran the sub pre out from the reciever and used the "Y" connection to go left and right on Hafler. Hooked left and right to both subs, set the gain on the Onkyo to "0" and popped in Animusic. I believe running a raw amp is a great improvement from the plate amps. The subs disapeared in my living room. Being I have my beautiful vintage Polk 7's as front main, I set my reciever to 60hz. Now I know some of you might think that alittle low, but the Polks handle the rest beautifuly and blend everything in very well. I just want to thank all of you for giving me such great help. And if there is anything I can help with , let me know. I cant wait to dismantle those terrible manufacture sub boxes and use Win Isd to create bigger, better and lower tuned boxes for my 10" Polk and 12" MTX. Jake |
#52 |
Glad to hear that it worked.
#53 |
It works great, burnedfingers. But I didnt realize how warm that amp ran. Is it safe to just leave it on? Or should I turn it off and on everytime I use it. The rest of my electronics stay on allways. I believe that leaving them on reduces moister that can currode connection. Am I right in leaving this particular amp on?
#54 |
The purests would say to let all your gear run. In todays world with the increasing cost of electricity I would suggest turning on the equipment about 1/2 hour before listening to it. To answer your question I would not let it run. I would also check the bias to make sure it is tracking correctly and is set per factory specifications. As you know the sign of heat can sometimes mean the bias is a little heavy.
Actually I would turn off your gear. Turn it on 1/2 prior to using. I wouldn't worry about a moisture problem or corrosion. |
#55 |
The heat is not unusual heat (if that makes any since). As a matter of fact on my Onkyo reciever I can cook an egg (figuratively speaking), the Hafler isnt as warm as the Onkyo.
#56 | |
I'd leave the amp on all the time, because you don't want to burn out the switch again. It's days are numbered. |
#57 |
Hi Jake,
I am solidly on the turn your gear off side. Many reasons to do so and very few weak arguments to leave it on. Turn it all off and follow Joe's (burnedfingers) sage advice. You can easily add a soft start, or just replace the switch when needed. -Chris |
#58 |
I have already asked Hafler tech support and it says 260 ma for DC bias.
#59 |
To measure bias in fuse clips, use a 1 ohm resistor, I also have 0R1 ohm resistors for this purpose.
Remember to remove them before packing it up or running it hard. You will learn the hard way like I have a few times. -Chris |
| Hafler 9500 Power Switch | partialresponse | Solid State | 1 | 22nd October 2009 08:12 PM |
| Hafler XL280 Thermal/Heat Switch? | RnR | Solid State | 3 | 16th July 2009 05:33 PM |
| switch-on, switch-off sequence for preamp/amp | cbutterworth | Tubes / Valves | 1 | 2nd March 2007 01:41 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 10:24 AM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 09:23 PM |
| Page generated in 0.12625 seconds (79.97% PHP - 20.03% MySQL) with 11 queries |
