Old 17th March 2006, 01:14 AM   #41
Grey and Chris are correct on the switch issues and about bridging. Thirty years ago when I was a pup I probably blew up more amplifiers than 1/4 of the population of people in my town own. Hell, when you can bridge a 8 ohm load why not throw caution to the wind and run her on a 4 ohm load. Heck, it will last a while. Funny thing about speakers is the impedance goes down with the frequency. What was an 8 ohm nominal speaker impedance may dip to 3 ohms at say 20 HZ. Another funny thing about amplifiers is that unless they are specifically designed to mono bridge your best bet is to leave them to hell alone. Example
An Altec model 9446 is a commercial amplifier that was designed to mono bridge. Note* Has bridging circuitry designed in. Unit will
run day in and day out bridged. The Mickey Mouse bridging adaptor is minimal at best and I could probably ramble on for a page about adequate heatsinking, DC offset, Bias circuit problems and a few other considerations.
Personally, I believe the amplifier in question has serious problems that need to be taken care of by a qualified individual.
Hook the thing up to a variac and run it up and test it. The it ran good belore answer won't cut it with some of us because we know that in the world of electronics something can work one minute and fail after that. It has age on it and **** happens. Rebuild it or send it down the road and move on.
Old 17th March 2006, 03:18 AM   #42
If the poor thing needs a home, send it to me. I like the silly things.
Grey
Old 17th March 2006, 05:33 AM   #43
I admit, I get excited and ask question after question. My fault. I will give this amp a good home as soon as I bring it back to life. I'm waiting on the Carling switch I ordered. As soon as it comes in I'll install it and see what I'm working with. I'm not bridgeing it out. I figured at 8ohms I get a good 100watts, so at 4ohm I should get close to double that. Which should be all the "naked" juice I need. Hell, I might even invest in a good DVC sub and run both channels. But for now I'll just wait on the switch and try not to get too ahead of myself.
Jake
Old 17th March 2006, 05:39 AM   #44
Oh I know Burn. Electronics are like cars. Just cause it started yesturday dont mean it will start today
Old 17th March 2006, 02:31 PM   #45
I don't remember the DH-200 being biased heavily enough to double into 4 Ohms. Probably closer to 150W at a guess.
I've got a couple of the manuals around here somewhere. If I get a chance, I'll dredge one up and see what the 4 Ohm wattage was.
Grey
Old 17th March 2006, 02:36 PM   #46
anatech is offline anatech  Canada
anatech's Avatar
Hi Jake,
I like these amps too. I don't want to see it die.
If you bridge it, the minimum impedance is 8 ohms total. You would be further ahead to run each woofer off it's own channel, non-bridged.
-Chris
Old 17th March 2006, 03:19 PM   #47
Ordered the switch yesturday morning. Still no comfirmation from Mouser. Almost 24 hours later. So aggrivating.
Jake
Old 17th March 2006, 03:22 PM   #48
What I read somewhere (might have been here at DIY) that the amp is 100wpc @ 8ohms. And that is was close to double wpc @ 4ohms. Still 150wpc @ 4ohms from a solid amp like this will blow away that cheep little MTX amp.
Jake
Old 18th March 2006, 01:34 AM   #49
fab is offline fab  Canada
fab's Avatar
Cool Power of DH-200
From what I remember I have measured about 130W rms / 8 ohms and I think close to 180 W rms / 4 ohms before seeing clipping on the scope...
Old 20th March 2006, 02:49 PM   #50
Then thats perfect for my little MTX.
Hafler 9500 Power Switch partialresponse Solid State 1 22nd October 2009 08:12 PM
Hafler XL280 Thermal/Heat Switch? RnR Solid State 3 16th July 2009 05:33 PM
switch-on, switch-off sequence for preamp/amp cbutterworth Tubes / Valves 1 2nd March 2007 01:41 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 10:24 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 09:23 PM
Page generated in 0.10762 seconds (79.17% PHP - 20.83% MySQL) with 11 queries
