Old 15th March 2006, 08:55 PM   #11
If memory serves me right. This is the switch I bought http://www.radioshack.com/product/in...entPage=search
Accept it was a 125v switch
Old 15th March 2006, 08:55 PM   #12
BobEllis's Avatar
You can remove the capacitor without killing the amp. You may cause interference with other electronics or even a speaker damaging pop when you turn your amp off without it. You will shorten the life of the switch.
Old 15th March 2006, 09:06 PM   #13
That is a 5amp slow burn fuse right?
Old 15th March 2006, 09:16 PM   #14
BobEllis's Avatar
In that case, it probably was a resistor used to limit the current through the lamp.
go back to Chris' comments about figuring out what each connection is. You probably got them mixed up and ended up placing the switch across the mains. Was there a diagram on the back of the Radio Shack package?
I don't have your manual handy, but 5A slow blow sounds about right.
Old 15th March 2006, 09:22 PM   #15
anatech is offline anatech  Canada
anatech's Avatar
Hi jakelm3075,
Yes, it's a 5 A slow blow rated at at least 120VAC (not a 32V fuse!).
Different makes of switches may have their own terminal connections. This will be printed on the switch itself normally. Check the packaging. Leave the capacitor in. It protects the switch contacts as Bob pointed out.
-Chris
Old 15th March 2006, 09:25 PM   #16
Speaking if switches. Is there a right and wrong switch? If I picked up a 12v switch instead of a 125v switch or if the amps for the switch are 10amp instead of 30amp.
Knowing me I'll get home and redo the connection and blow the house up. I do not like 120 current. My wife will be sitting peicefully watching Survivor and pooof there go the lights.
Old 15th March 2006, 10:41 PM   #17
Several points:
--One--give up on Radio Shack. The switch you need is Mouser part# 691-LTA201TRB/125N. They're about $3-4.00 or so. Don't pay the guy on ebay who wants $15. That's silly. For a nickel and a cup full of good wishes, I'd do a group buy on Hafler switches, get 100, and sell them for $5-6. $15 is highway robbery.
--Two--do not use those switches without the spark suppressor caps. The turn-on surge creates a millisecond arc that pits the contacts. Eventually they weld. The Hafler switches were notorious for giving up. We kept a box of replacements handy back when I sold Haflers.
--Three--personally, I'd recommend going to .01uF on the suppressor cap. Stock was (I think) .005uF, and it wasn't (in my opinion) enough. Ceramic disc caps are cheap. It's worth 10 cents of insurance to make the switch happy. Of course, part of the problem was that the older version of the switch was rated for 10A. The newer version is rated for 15A.
--Four--no, all switches aren't alike. Just because it's got three connections doesn't mean that it's the same pinout as another switch with three connections.
--Five--it's not a bad idea to put a cap across any power switch that will see a high-current surge. Again, cheap insurance, no matter who makes the switch or what the current ratings are.
There may have been other points raised, but I'm up to my rump in alligators at the moment and just tried to hit the high spots.
Grey
Old 15th March 2006, 11:04 PM   #18
Well Grey, Thanks big time for the info and time. Where would I go to purchase the switch you mentioned? And I will go to a .01uF disk.
You dont have, by any chance, some switches left??
Old 15th March 2006, 11:12 PM   #19
Grey, what is your take on gain control in my situation? Running from sub preout directly to amp. Do you think I will have enough gain control? I dont like to run my gain over +1 or+2 on the reciever. I was told running gain too high on the reciever causes distorion and loss of sound quality.
Jake
Old 15th March 2006, 11:15 PM   #20
BobEllis's Avatar
Originally posted by GRollins
The switch you need is Mouser part# 691-LTA201TRB/125N. ...Grey
Be sure to use a line rated cap, like Mouser part 75-125ld50 Or a higher capacitance version as grey mentioned.
sub out to amp is normally the way things run. If you are having trouble getting the sub loud enough, you may be able to set your receiver to attenuate the mains a bit.
Hafler 9500 Power Switch partialresponse Solid State 1 22nd October 2009 08:12 PM
Hafler XL280 Thermal/Heat Switch? RnR Solid State 3 16th July 2009 05:33 PM
switch-on, switch-off sequence for preamp/amp cbutterworth Tubes / Valves 1 2nd March 2007 01:41 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 10:24 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 09:23 PM
Page generated in 0.10941 seconds (77.72% PHP - 22.28% MySQL) with 11 queries
