This problem started seeking a solution a week ago with the name of "testing FET transistors"
My hunch of a muffled buzzing and crackling sound comming from the left channel of my 88 princeton chorus turned from a blown transistor problem to wide spectrum of causes including dirty pot connections, leaky capacitors, fried resistors, and transformer problems. I have now found that 40-50 volts is being sent from the left output. Are there any normal causes for this? How can i fix them if so? |
#2 |
If the amp is so damaged as you describe, I'm not surprised it has that much DC on the output.
Start with finding a schematic if you don't have it, measure every semiconductor and resistor. Recap thoroughly. Try to decouple the output stage and use a variac. Good luck. Can you share a picture? /Hugo |
#3 |
Hugo,
The transistor in question turned out to be an IC amp chip. sound_prodigy, If things were that easy we wouldn't need trained technicians and test equipment. Like a detective, you need to find out some facts and follow clues to the answer. Get the schematic and make some measurements. I did link to the IC data sheet, so start by measuring all the voltages with respect to ground and posting. -Chris |
#4 |
Well this thread should go to chip amps then?
I should have asked for a schematic. /Hugo |
#5 |
Hi Hugo,
I think we should have continued the same thread as before to provide continuity. Waiting input from sound_prodigy. I want to be certain it's the same amp. -Chris |
| low audio on left channel jvc vn-300 | stevodude | Solid State | 5 | 22nd February 2011 07:56 AM |
| K-502 Left Channel is out | udailey | Tubes / Valves | 3 | 21st March 2008 05:12 PM |
| Page generated in 0.06914 seconds (76.65% PHP - 23.35% MySQL) with 10 queries |
