Why is 40 volts DC comming out of my amps left channel? Why is 40 volts DC comming out of my amps left channel? - diyAudio
Old 13th March 2006, 07:51 PM   #1
sound_prodigy is offline sound_prodigy  United States
Default Why is 40 volts DC comming out of my amps left channel?
This problem started seeking a solution a week ago with the name of "testing FET transistors"
My hunch of a muffled buzzing and crackling sound comming from the left channel of my 88 princeton chorus turned from a blown transistor problem to wide spectrum of causes including dirty pot connections, leaky capacitors, fried resistors, and transformer problems. I have now found that 40-50 volts is being sent from the left output.
Are there any normal causes for this?
How can i fix them if so?
Old 13th March 2006, 08:11 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
If the amp is so damaged as you describe, I'm not surprised it has that much DC on the output.
Start with finding a schematic if you don't have it, measure every semiconductor and resistor. Recap thoroughly. Try to decouple the output stage and use a variac.
Good luck. Can you share a picture?
/Hugo
Old 14th March 2006, 01:40 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hugo,
The transistor in question turned out to be an IC amp chip.
sound_prodigy,
If things were that easy we wouldn't need trained technicians and test equipment. Like a detective, you need to find out some facts and follow clues to the answer.
Get the schematic and make some measurements. I did link to the IC data sheet, so start by measuring all the voltages with respect to ground and posting.
-Chris
Old 14th March 2006, 05:38 PM   #4
Netlist's Avatar
Well this thread should go to chip amps then?
I should have asked for a schematic.
/Hugo
Old 14th March 2006, 05:44 PM   #5
anatech's Avatar
Hi Hugo,
I think we should have continued the same thread as before to provide continuity. Waiting input from sound_prodigy. I want to be certain it's the same amp.
-Chris
Why is 40 volts DC comming out of my amps left channel?Hide this!Advertise here!
low audio on left channel jvc vn-300 stevodude Solid State 8 10th February 2014 02:15 PM
K-502 Left Channel is out udailey Tubes / Valves 3 21st March 2008 05:12 PM
Copyright ©1999-2017 diyAudio
