High THD, Poor RCA Connections
Old 13th March 2006, 10:13 AM   #1
goeat is offline goeat  United States
Send a message via AIM to goeat
Default High THD, Poor RCA Connections
I can imagine that this is a popular problem, but I couldn't for the life of my find a related thread using the search, so...
This is for equipment that I've bought, mainly a NAD 1130 Preamp and an Adcom GFA-555 MKI. I'm having a lot of problems getting a good connection between the preamp and the amp with any RCA cable (high or low quality), being especially twitchy at the preamp side of things, often resulting in loud pops and emormous amounts of distortion (~90%) should the cable be jostled. The connection at the amplifier is solid.
Some things that have been recommended to me as problems:
-Ground loop problem between the amp and the preamp's wall connection.
-Ground loop problem within the preamp.
-Poor RCA connections on the preamp.
-Faulty RCA wiring on the preamp.
Are these in the right direction?
I plan on taking apart the preamp tomorrow, mostly to see what's up in there. If anyone can provide any insight as to the RCA issue, thank you in advance. I can provide more information on how these are wired together/to wall power if anyone cares to know.
Greg
Old 13th March 2006, 10:16 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
It's nothing to do with ground loops. Simply the RCA connection - probably the springy part that forms the centre contact, or the ground contact - is a bit loose somewhere.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 13th March 2006, 04:50 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It looks like an oxidized contact or a bad solder joint in the female RCA connector.
Old 14th March 2006, 02:43 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
I think Eva's on track. Many newer products have RCA connectors that get cracked solder joints on the PCB. Once you get in there, resolder the lot.
Also, Adcom amps have a resistor between ground and signal ground on the order of 100 ohms. You should measure 200 ohms between the RCA grounds (with the amp turned off!!).
-Chris
Old 14th March 2006, 03:57 AM   #5
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
> Post #3
Or similar problem with the RCA jack.
High THD, Poor RCA ConnectionsHide this!Advertise here!
Poor Man's Strad peace brainerd Multi-Way 76 20th July 2015 08:09 PM
Help a poor noob pls! jw2k_fr Multi-Way 20 9th February 2010 10:29 PM
my poor power amp... :-( timfishy Solid State 23 31st August 2004 01:55 AM
Plate amps- high vs low ohm connections? amt Solid State 1 30th January 2004 11:24 PM
