Hello, all!
I'm currently working on getting parts for a gainclone, and wanted to try getting a stepped attenuator for use for volume control, possibly in a preamp. However, instead of using the standard-issue rotary switches, I'd like to try using a set of resistors and relays controlled by a microprocessor. (I'm also learning how to program these.) Using a remote, one could control which resistors were connected; by using a bunch of relays with SPST connections, they could be moved in and out of the circut. (When the relay's on, it would bypass the resistor). Would this work? Also, could I use a set of relays for an input selector circut? I've got some PIC microcontroller gear, and it looks like might be easy (and fun!) to make a fancy-pants remote control system for a pittance. (10$ for the microcontroller, a few $ worth of transistors, and some relays harvested from old modems is all I'd need!) Also, this might work rather nicely in conjunction with a built-in computer. I've got a small industrial computer board which would fit inside half of an old CD player enclosure quite nicely; with a gainclone on the other side and a DVD drive, I'd have a nifty little HTPC! |
#2 |
To get your mind started:
http://www.mhennessy.f9.co.uk/preamp...e_research.htm Constant impedance relay-resistor logarithmic attenuator http://jos.vaneijndhoven.net/switchr/design.html I'm also doing a similar project, you might wanna look here too My (semi-)reference preamplifier
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots. |
#3 |
You might consider a digital pot.
Many IC manufacturers make them. As for relays, why not use a IC switch? 4016 and 4066 (I think) are the part numbers. An article by Doug Self showed them to be rather low distortion when used in a shunt configuration. |
#4 | |
The chip switches also sound like an interesting idea. |
#5 | |
http://www.analog.com/UploadedFiles/...58AD5290_0.pdf |
#6 |
There are several IC's like the PGA2311 which are basically a stepped attenuator in a chip. Easily controlled by a microcontroller.
The power of Science compels you! |
| I ned a 6ch digitally-controlled attenuator. Anyone know of a design? | Spasticteapot | Digital Line Level | 2 | 27th February 2009 08:17 PM |
| Digitally controlled LED panel help... | needtubes | Everything Else | 0 | 28th June 2007 01:53 AM |
| Remote Controlled Stepped Attenuator | Miniwatt | Tubes / Valves | 4 | 27th January 2006 05:22 PM |
| Digitally controlled Baxandall? | BoGoMiPz | Solid State | 21 | 19th February 2004 01:41 PM |
| Page generated in 0.10426 seconds (70.58% PHP - 29.42% MySQL) with 10 queries |
