Audio Junkie
I needed a volume control to hold me over until i can get my Passive Line stage built. Digging around my junk piles i found a P&G pot that
I slapped into a project box with a Cheapo RCA Cable cut in half for In/Out. this works, but there is a bit of minor background hum. I never even thought about the ground loop that would be created by tying the In L-R and the out L-R grounds together. but sure enough HUM. Ok, so now, to avoid that in the construction of the Passive Line stage. How should i ground the I/O?? I will be using isolated panel jacks. I would imagine i need to somehow break the loop on the output side of the attenuator? I thought i read someplace that a small value resistor to ground would be enough to break the ground loop, yet still provide enough of a return path. But will this then add to the loss through the box?? So if we have the Input of the box going to pins 1 & 3 of the pot, and the output from the Wiper and then what should we do with the output ground? 100 ohm resistor to Pin 3 of the pot and the output jack ground??? Please Advise |
#2 | |
Why do you have to do that? |
#3 | |
Audio Junkie
#4 |
don't get it. no need for any connections between L & R - you can treat the attenuator as separate mono attenuators for each channel. Or am i not getting your words right?
#5 |
keep your signal returns separate from each other and separate from the enclosure. Insulated RCAs sound right. Try using screened 2core for each channel with the screen connected at one end only.
regards Andrew T. |
#6 |
Audio Junkie
Sorry i didnt make it as clear as i should have. Yes the Left and right sections are treated seperatly. The left input ground is tied to Pin 3 of the pot and the output ground.
#7 |
Then you don't have a ground loop. Seek the explanation for the hum elsewhere.
Btw, AndrewT makes a good point about the jacks - are they really insulated? Is there hum if only one channel passes through the pot? |
#8 |
Audio Junkie
At the moment i dont even have jacks, i just have a cable running in and out of the box. and the hum is still there if i run just one channel.
When i got my C-J amp, it had a ground lift adapter on the power cord. The ground loop seems to be cause by the grounds of the audio gear and the audio cables. lifting the ground of the amp makes it go away. |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Passive line stage with tubes | Glowbug | Tubes / Valves | 6 | 17th March 2006 03:14 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Balanced Line Stage - grounding scheme | Possum | Pass Labs | 6 | 18th December 2003 10:07 AM |
| Grounding thev Balanced line stage(BoSoz) | Amj_ciron | Pass Labs | 21 | 16th July 2002 12:22 PM |
| Page generated in 0.08340 seconds (78.91% PHP - 21.09% MySQL) with 10 queries |
