Old 7th March 2006, 06:24 AM   #1
freo is offline freo  Australia
Default Improving Heatsinks
Hello
has anyone any ideas on how to make heatsinks more efficient, I have a class a amp that runs very hot especially here in the 100 degree Australian summer I thought about sticking the fins of another heatsink into the existing one, or mabeye running some copper wire from the existing heatsinks any ideas would be welcome
Regards Roger
Old 7th March 2006, 06:39 AM   #2
move to the UK.
They will run a lot cooler here.
Particularly in the Scottish Borders where some more snow fell overnight. It's all white again.
regards Andrew T.
Old 7th March 2006, 06:44 AM   #3
sangram is offline sangram  India
Default Re: Improving Heatsinks
Originally posted by freo
Hello
Hi
A 12 Volt fan run at 6 volts (or two connected in series) could halve the heatsink temperature.
Sangram
Old 7th March 2006, 06:45 AM   #4
Originally posted by AndrewT
... some more snow fell overnight. It's all white again.
I'm jealous!! We're approaching a summer which is supposed to be one of the worst in the subcontinent, with 40 degree temperatures.
Old 7th March 2006, 06:47 AM   #5
Greg Erskine's Avatar
hi freo,
Ensure fins are vertical.
Make sure the fins have good air flow.
Make them bigger.
Add a fan or two.
Black heatsinks are better.
regards
Greg Erskine
Old 7th March 2006, 07:37 AM   #6
ensure the bottom entry of the sink is clear of the floor/support shelf.
The cold (38degC) air needs to get in efficiently before it can get out.
Are the sinks clean - no dust/grime?
Would you consider the fan cooling just mentioned by Snagram & Greg?
Only for summer use.
Build a support frame with a bottom feed fan and an exist slot directly under your sink. Although not in the best location it will reduce your Tc.
regards Andrew T.
Old 13th March 2006, 09:49 AM   #7
he did not understand the subtlety of my offer to take his amp off his hands.
Just an update on the weather.
I can't get to work today (Monday). Still snowed in from Saturday morning's snowfall/drifting.
regards Andrew T.
Old 13th March 2006, 11:11 AM   #8
darkfenriz's Avatar
If you have plastic can devices you can use some thin copper blocks, of reasonably greater area than to247, each for every group of devices with the same potential at collector/drain. The trick is to use washer not between device and copper block, but between copper block and aluminium heatsink.
However I bet your heatsink is colder than you'd think. You know, water of 160F won't make you harm, freon of 130F will, and so will aluminium.
improving diy loudspeaker milen007 Multi-Way 16 28th April 2009 10:36 AM
Improving Heatsinks for an Amplifier? pjpoes Parts 23 31st December 2007 05:50 PM
Help me improving my pre-amp! thanh Solid State 0 26th January 2007 10:08 AM
improving new system Taz Digital Source 1 14th May 2006 11:41 AM
improving my VAS djdamix Solid State 27 13th February 2005 12:54 PM
Page generated in 0.08287 seconds (84.44% PHP - 15.56% MySQL) with 10 queries
