I have found a couple of TO-3 power transistors made by RCA that I don't know the specs for. I was planning to build a car sub amplifier using a 2n5631 and a 2n6031 that I had in the parts bin but just found out that the 2n6031 has all its terminals shorted together.
![]() In the parts bin there are a couple of telecom power supplies that convert 50V to +-10V or +-15V. They use two of RCA (SGS in some of them) N121230-3 NPNs driving a transformer in push-pull so they have to be at least 100V parts. I have at least 8 of these so I could parallell if needed. I saw them mentioned in this thread: Rca Mosfet? One poster claims them to be 120V, 12A. Does anyone know max power dissipation or any other useful data? I also have 2 of RCA N121122 NPN transistors, but they were used in another application, as a standard class B amplifier driven by a single 50V rail used to generate ringing voltage. I don't know how heavy load it was supposed to drive, but probably not too heavy as the emitter resistors are 1 ohm. My power supply puts out +-40V unloaded with 14V input. I have not measured how much it sags under load as I have built it on a breadboard and I don't want stuff melting |
#2 |
Switching power supply transistors have no safe area when operated in a linear amplifier.
I have 600pcs of 2N6274, a 50A, 30Mhz, 100V, 250W part. They cost over $40 each 20+ years ago. At 7V they will handle the full 250W, at 100V the SOA is only 6W !!! The MJ15015/16 pair have 180W SOA at 60V, and only cost about $1.50 each, used in Crown, Carver, and others. |
#3 |
Well, power transistors aren't that cheap here in Sweden I'm afraid
I found 2 pairs of 2SD718 and 2SB688 in the parts bin. Datasheets can be found on alldatasheet.com and they look suitable. I'll use both pairs in the amp. The speaker is 8 ohms so the amp shouldn't complain too much. The circuit is going to be a mix between P3A and Douglas Self's Blameless amplifier. |
#4 |
$7?
Ouch! I paid $1.23 for the MJ15015s and $1.30 for the MJ15016s. The 2SD718 and 2SB688 should be fine for what you want. |
| Transistor Beta Numbers & Matching Q? | Zero Cool | Solid State | 12 | 18th May 2006 03:41 PM |
| Totally Unfamiliar Transistor Numbers...??? | EchoWars | Solid State | 9 | 26th September 2005 09:02 PM |
| transistor part numbers | bjr | Parts | 2 | 4th September 2005 04:26 PM |
| Page generated in 0.13054 seconds (44.03% PHP - 55.97% MySQL) with 10 queries |
