Old 6th March 2006, 09:30 AM   #1
beppe61 is offline beppe61  Italy
Default A line preamp schematic working with 12V PS.
Dear Friends,
after many many ramblings I have set for a line preamp to be powered with a 12V power supply using SLABatteries.
A friend of mine is modding (primarly updgrading input and output connectors) a T-Amp.
The fact that 12V suffice for an amp had convinced me that should suffice even more for a line preamp.
So I am looking for suggestion about a very simple circuit with gain about 3 and with good performance at 2 V output with a load of 10 kohm.
Something of the like of the schematic attached.
Any suggestion about a suitable schematic would be very much welcomed and appreciated.
thank you very much.
Kind regards,
bg
Old 6th March 2006, 09:46 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
That circuit uses 48 Volt DC.
May be some resistors need other values.
Good to know this:
- 12 Volt single supply
- Voltage gain ~3
- 2 Volt RMS output voltage
~10 kOhm load
this will make easier to give good advice
Regards and thank you very much
lineup
lineup
Old 6th March 2006, 10:00 AM   #3
Originally posted by lineup
1) That circuit uses 48 Volt DC.
2) Good to know this:
- Voltage gain ~3
~10 kOhm load
lineup
Dear Mr. Lineup,
thank you for your always kind and valuable reply.
1) I know.
I attached the schematic just to explain the kind of circuit I am looking for.
A very simple circuit.
I expect most of the benefits from the battery PS.
2) Actually these should be the normal requirements for a line preamp to be used with digital sources and able to drive most of the power amps to full power.
Anyway I would like to stay "discrete" (i.e. no-opamp).
If you have any suggestion I am here.
Kind regards,
bg
Old 6th March 2006, 01:27 PM   #4
Something like this?
Current drain is about 2.5 mA per channel.
This configuration has good supply rejection.
Old 6th March 2006, 01:43 PM   #5
Originally posted by davidsrsb
1) Something like this?
2) Current drain is about 2.5 mA per channel.
3) This configuration has good supply rejection.
1) Exactly Sir, thank you very much indeed.
I meant something like that.
Extremely simple but also nice.
2) Very good figure.
Is the current drain constant (i.e. is the circuit class A)?
If so, as I intend to use at least a 6Ah SLAB, the battery should last 6000/5= 1200 hours.
Is my calculation wrong?
3) Well, with batteries this should not be mandatory.
Nevertheless a nice plus.
Have you actually build this circuit?
How does it sound?
Thank you very much again.
Kind regards,
bg
Old 6th March 2006, 02:58 PM   #6
The amplifier is class A and will work from 14V down to 10V during the battery discharge.
I used to use this sort of circuit, at higher current, as a video amplifier.
With normal audio transistors it does not need a compensation capacitor.
Old 6th March 2006, 03:10 PM   #7
1) The amplifier is class A and will work from 14V down to 10V during the battery discharge.
2) I used to use this sort of circuit, at higher current, as a video amplifier.
Dear Sir,
thank you so much again for your very kind and valuable reply.
1) Class A means a constant current draw.
So no big buffer caps are needed at the output.
Very good.
2) I hope the bandwidth and distortion figures are good also at with a low 12V supply.
As I said I thought about a 12V SLAB:
1) on the basis of the great opinions read about a smal wattage (6W/8ohm) high quality power amp powered with a single 7Ah 12V SLAB
2) after reading that the noise of a SLAB is unmeasurable !
3) considering that the current consumption of such simple circuits is very minimal, so that the SLAB's charge should be sufficiently long lasting from a practical point of view (at least about 1 charge/week).
I strongly think that a circuit like this has good chances to sound very good indeed.
Very "black" background for music and very nice transparency.
I will report soon.
Kind regards,
beppe
working out component values for bc108 preamp stevie j Solid State 2 18th July 2007 11:19 PM
working sub schematic steven344 Subwoofers 1 27th November 2005 05:19 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Nelson PASS Bride of Zen Preamp Board Stuffed & Working AD Swap Meet 8 27th May 2004 08:54 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Page generated in 0.09267 seconds (80.89% PHP - 19.11% MySQL) with 11 queries
