#41 |
hello "viktor1986"
I hope is not a problem to respond in romanian language for victor am mai multe bucati din IRFP, si de aceia intrebam, in plus 2sk1058/2sj162 sunt la preturi foarte mari aici ......... |
#42 |
Maldanut in my country price for 2SK1058 is something around 7E and for IRFP is 2E.
Pa mislim sta reci! |
#43 |
helo everyone,
I have been around for a while, reading and reading and reading,, till now I can arrange all parts here locally (I am from India Mumbai) i can even get the PCB done not a problem. My electronic knowledge is also good enough for this project. I wanna build a 5.1 system using this amp design. What i wanna know is how should i power it ? How many secondary winding should be there for the transformer so it can power six of these little beast. I have got a transformer which gives me +/- 45 at 5amps will this single line be enough to power all six cuircuts.? Or am i missing somthing..? Any help on the power issue shall be nice Thanx Mastero |
#44 |
yes victor this is the point whit the tranzistor replacement, and I now well they are not the same SK,SJ whit IRFP gest I ask for help, so I had respond to your question.can you HELP ???
tanx |
#45 | |
I can only salute to your intention to do that, but I believe it might be an overkill to make entire 5.1 system by using only Studio amp modules (if I understand your plan properly?!). That transformer is certainly not sufficient for all of that. It will supply more than nicely one stereo Studio amp to a full specs, but six modules... no way! Yes, you can, for example, run Studio for satellites on 5 or 10W, but it is like buying a racing car and then never drives it more than 50km/h for the rest of your life! |
#46 |
Hello everybody!
I am writing this to contribute and inform DIY community about another design by Dr. Bora Jagodic. I found that thread on the best Croatian Audiofil.net DIY forum two days ago, and I thought it is worth sharing it with wider audio community. It is about his power amplifier design named "Techno" that has been built and tested by well known and respectable Croatian audiophile and DIY enthusiast "Dioklecijan" that he published on Croatian Audiofil.net forum. My old friend from school, which speak English better than me, helped me to make this translation of his posts: "This days I've finished amplifier Techno with output stage done according to schematics from Borivoje Jagodic. You can find that schematic on his site: http://bas.elitesecurity.org/mojiprojekti1.html . Preamplifier stage is my own idea with SMD OPAMP-s TLE2071. Here are some photographs of progress of that project: http://img.photobucket.com/albums/v6...n/IMG_0878.jpg http://img.photobucket.com/albums/v6...IMG_0877_1.jpg http://img.photobucket.com/albums/v6...cijan/amp1.jpg Here is how it looks today: http://img.photobucket.com/albums/v6...IMG_1080_1.jpg and here is how it will look when I finally close the case-enclosure: http://img.photobucket.com/albums/v6...IMG_1077_1.jpg Some technical aspects: Output transistors are ONSEMI 2SA1302/2SC3281 (thanks to "Pinco"), and the rest is all according to schematic. Because those transistors have high GBW it is necessary to put capacitor of between 150-330pF in parallel to existing 10k resistor at the input of amp. Otherwise it might oscillate! Everything else should be done by schematic. Mains transformers were 29V/200VA per channel + separate transformer for preamp. Amplifier posses power in abundance. Control is immaculate, and in my tests it was working with Focal Electra 1028, and with Electra 905, Diapason Micra and JBL CM42. Amp is biased at 90mA and if anyone is going to build it I suggest bigger heatsinks than mine. Sound of this amplifier is very pleasant for listening, with extraordinary dynamic and excellent detaileness. As audiophiles would say "it sound musically". Under 10.000 kuna (Croatian national currency, about ??kuna=1Euro) in the shop you won't find better amp. This is valid if amp is done properly and with high quality components!" Second post: " http://img.photobucket.com/albums/v6...IMG_1082_1.jpg http://img.photobucket.com/albums/v6...n/IMG_1081.jpg Here is the preamplifier. It consist of input buffer and second stage with 6dB gain, which is very low but amp itself has high gain so together it is enough. I also predict a variable output for connection of subwoofer or alike and that stage has slightly higher gain of around 9dB. Supply is standard with LM317/337 but maybe one day it will be replaced with some superregulator version. Answer to Boban's question: With regards to a character of the sound, I will put Techno somewhere between Audio Analogue Puccini SE and Rotel 1070, and I'll say it took musicality from Puccini and detailness from Rotel, but overall impression is that it is better than both those amplifiers! Of course, it slightly lacks that specific transparency that PassAleph5 posses (but anyway that is a specific virtue of Pass masterpieces). For real assessment, I believe, it will take more than this 10 days that I spent with sound of Techno amplifier." Dioklecijan's setup: Marantz CD14, Nottingham Analogue Spacedeck-Benz Micro ACE, Denon DVD3910, Sansui TU-X1, DIY; Phono Preamp, Pass Labs BLS, Pass Labs Aleph 5; Focal Electra 1027BE, VDH 102MKIII, Cable Talk Concert
#47 |
10.000 Kuna
1 Euro~ 7,2 Kuna so ~1388 Euro bloody much I'll have two Alephs for that money
my Papa is smarter than your Nelson ! tnx to |
#48 | |
Non é mai abbastanza... |
#49 | |
??kuna=1Euro) in the shop you won't find better amp In the shop for that price, not DIY, In DIY you can for cca, 250E build that amp with dual mono PSU, H3 rack metal box, and quality parts, without preamp, and if you have some parts at home from preavius projects.... |
#50 | ||
agree with you and Aparatusonitus..... in fact-my post wasn't clear ,exactly as #46 post - I meant that I believe that real expenses must be several times lower,knowing few things about "domestic" DIY-ers ....... regarding resulted sound in class of at least 10.000 kuna, that is already rule ,what you get when you do it right.....in fact- that 's easy ,looking at what garbage ppl are used to sell and buy under fifi or fi-end label ![]() EDIT: in #46 post Quote:
seems that I totaly slipped that sentence.......after few sleepless nigts maybe it is normal hehe......
| marantz 250 amplifer | reg Tomasello | Solid State | 0 | 12th January 2009 06:22 PM |
| DBX BX-3 Amplifer Woes...What is going on? | EchoWars | Solid State | 13 | 6th April 2008 04:03 AM |
| Amplifer calculation | irdeto | Tubes / Valves | 6 | 19th February 2007 09:00 AM |
| Amplifer HELP!!!! | Pate | Solid State | 0 | 21st November 2005 05:16 AM |
| Page generated in 0.14376 seconds (86.48% PHP - 13.52% MySQL) with 11 queries |
