Old 3rd March 2006, 10:10 PM   #1
glen65 is offline glen65  United States
Default Transistor Id
I’ve been trying to find the info on this transistor but haven’t successful. It says C107 so I figured it might be a 2sc107 but no dice. It does have some odd readings when testing it. It may have built in resistors. It’s being used in a RCA 50 watt receiver made for Radio Shack. The model is STA3850. It’s being used on a small power supply board. I will post a couple of pics.
Any info appreciated.
thanks
Old 3rd March 2006, 10:12 PM   #2
Here is another view
Old 3rd March 2006, 10:18 PM   #3
Tube_Dude's Avatar
I looks like a logic level switch ( a transistor with a base resistor )for to be driven by a logic signal...
Jorge
Old 3rd March 2006, 10:51 PM   #4
Yes it does appear to be something along those lines.
I just havent been able to find any data on it so I can come up
with a replacement for it.
Old 4th March 2006, 12:44 AM   #5
clem_o is offline clem_o  Philippines
If its used to logic-switch, it can't be too critical? Trace the circuit, figure its polarity and perhaps just replace with a generic transistor with a small resistor inserted in series with the base?
Cheers
Old 4th March 2006, 01:09 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi glen65,
It looks to be a DTC107 logic transistor I'm guessing. NPN. They are sometimes called an inverter. Clem is right, they are just a transistor with a pair of built in resistors.
A search pointed to Sony, Rohm made those series of parts. Measure the drops between B and C, E.
Is that for AC detect? Measure the voltages when the unit is on.
-Chris
Old 4th March 2006, 02:52 AM   #7
Thanks for the response I was having trouble getting the receiver to power up. The standby light works ok. I pulled this transistor out to check it then put it back in and now the unit works. I suspect it could be an intermittent failure of the component.
That’s why I want to replace it.
thanks
Old 4th March 2006, 03:14 AM   #8
-Chris
B to E is 5.1 VDC
B to C is 4.5 VDC
If I remove the transistor the unit wont start. Press the power button once the standby led goes out. Press it again and the standby comes back on.
Old 4th March 2006, 03:31 AM   #9
diy guy is offline diy guy  Singapore
Default Transistor
Can it be a 2sc107
try this link
http://www.datasheetarchive.com/sear...ExactDS=Starts
diy guy
Old 4th March 2006, 02:35 PM   #10
anatech's Avatar
Hi diy guy,
Wrong case for one, this one is much more modern for two.
The most important clue .... 5 VDC on the base indicates an internal resistor. This confirms it as a digital switch transistor. A funny Sony number no less. There are DTC transistors that will sub fine. It works on 5V, so look in the logic sections of older VCRs and cassette decks. You may find something suitable on a board. DTA is the other polarity.
Try this link for more information http://www.rohm.com/products/shortfo...tr_index8.html
-Chris
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
what is this transistor (or fet) ? ASSaBeong Parts 7 26th April 2007 02:01 PM
503 transistor dazling69 Solid State 5 18th September 2005 09:03 PM
Best Transistor? samsagaz Solid State 13 18th October 2004 09:22 AM
Transistor ID EchoWars Solid State 6 24th January 2004 12:45 PM
Page generated in 0.12107 seconds (74.58% PHP - 25.42% MySQL) with 11 queries
