Hi. I was wondering is someone had any suggestions on what im about to ask. Are there any rackmount amplifiers that provide high grade sound at a relatively low price??>.............Im noticing that a lot of rackmount amplifiers are for dj's or are dj oriented. Do rackmount dj amplifiers such as, Crown, behringer, gemini, ART, differ all that much from standard amplifiers. I guess what im trying to ask is are they of enough quality to run a pair of good home audio monitors. Also does anybody have any suggestions for an audiophile grade rackmount amplifier for under $400?.
#2 | |
Hi rv1890,
Pro amplifiers are optimized for high power, high temperature fault tolerant operation. Some sound okay. Home audiophile grade amplifiers are optimized for sound quality. Some are able to put up with high temperature fault tolerant operation. Two different animals. $400 is scrapping the low end unless you find a gem used. -Chris |
#3 |
yes under $400 To name a few; QSC RMX series Crown XLS series Behringer EP series Carvin DCM series Carver ZR series, B-stock {or new for under $600} I wouldn't buy audiosource, gemini, pyle, pyramid, unsure about ART. If your budget is fatter, get some used QSC PLX series. |
#4 |
Check out Yamaha P7000S... Those things do as the spec sheet says....
#5 |
If i were to use this amplifier to run a couple monitors in my room would I be needing a preamp??
http://www.carvin.com/products/singl...DCM600&CID=PWA |
#6 |
Bryston
Perroux Hafler there are others, all can be purchased used for under $400.00 |
#7 |
We no longer buy amps at that price point and have moved to powered speakers. Way better bang for the buck as a system whole. If you don't already have speakers consider going powered.
Ears aren't microphones. |
| CMoy Audiophile Pocket Amplifier | DLJunkie | Swap Meet | 1 | 19th January 2007 04:33 AM |
| Non-standard rackmount | Nixie | Parts | 5 | 13th October 2006 01:29 AM |
| An audiophile amplifier for my TW dynaudio MD100 | willo | Car Audio | 9 | 25th March 2006 03:27 AM |
| My Rackmount SoZ | Super_BQ | Pass Labs | 14 | 1st March 2003 12:42 PM |
| 19" rackmount chassis | rafafredd | Parts | 3 | 9th December 2002 12:01 AM |
| Page generated in 0.09061 seconds (70.92% PHP - 29.08% MySQL) with 10 queries |
