Hi anyone have this?
Can only find one place on google that sells cds for 25 dollars. This thing has a blown channel and I havent recieved it yet. It also needs a new transformer, what are the rails on it? It uses HDAMS so I am thinking of replacing drivers and outputs on the blown channel, but a manual would help for some tweaking:-) |
#2 |
anyone??
#3 |
Hi Luke,
Sorry I can't help with the schematic, but what makes you think the power transformer is bad? Sometimes you can replace the thermal fuse if you can get to it. -Chris |
#4 | |
Hi Chris, Well the story goes, its belongs to a guy who was working abroad and got the voltage wrong, zapped one channel. This amp is 110V so I would change it 230V even if it were ok. What I dont know is if the transistors are hard to get and if I should just change them to the latest Toshibas on both channels anyway. one of my aims is to tweak the amp to see what performance I can get out of a low price amp. Currently I have aleph 2s, Krell ksa50, JLH couple of gainclones, so I am curious what I can get out of a midfi tweaked amp. seeya arthur |
#5 |
Hi Arthur,
Sounds like a plan. With any luck the guy just popped the fuse. When transformers overheat they generally make a sickly sweet / burnt smell. So you're making an amp for your computer speakers? -Chris |
#6 | |
Maybe it will give me the motivation to finish the Aleph-X. seeya arthur |
#7 |
I did that too! On my PM665. I'll see if I havea copy of the manual but I got mine from a very kind member on this site, maybe if you did a search...
I remember we had to replace the driver transistor. The main power supply caps would like to be changed after this sort of a thing, they were OK then but show accelerated aging... The transformers should mostly be OK, they could survive the x2 voltage. I changed out the transformer to custom units. The manual specified 53 volt rails, so I used 38 volt transformers... |
#8 |
I don't have schema for this amp, but I serviced one years ago adn, is same like pm68 inside exept some wiring and resistors which turns to class A. Regarding transformator, I think is 45volts per rail. Output trannies are toshiba 2SA1941/2SC5198 and, you have to be careful with those small metal boxes called hdam. Might happen sometimes any transistor to misbehave, so you have to check one by one. I agree, you better need schematics in order to fix it, it took my 1 month and half until i fix it... bekim |
#9 |
Hi Sangram and Bekim,
thanks or your input. I would have thought that the outputs and maybe drivers have failed. I hope not the hdam ![]() Bekin, is the transformer 45V or the rail voltage 45V? Maybe PM68 schematic is readily available on web. Thanks for the tip regards Arthur |
#10 |
45 volts is per rail, to be sure now, hmmm ... frankly, I forgot but, usualy this models have 45v per rail - pm68, 78, pm7000 & 8200..
be careful with zeners in preamp pcb.. bekim |
| Hifonics Service manual / schematic | camusmuse | Car Audio | 65 | 19th July 2011 02:07 AM |
| N.E.W. A-20 amp service manual or schematic | alaskahiatt | Solid State | 4 | 18th May 2011 12:30 AM |
| DCD1800 service manual / schematic | tritosine | Digital Source | 2 | 22nd February 2009 05:49 PM |
| Tascam M-50 Service manual or schematic | mike9999 | Solid State | 0 | 11th February 2008 02:36 PM |
| Schematic/Service Manual NAD 3150 | corrieb | Solid State | 2 | 6th February 2007 02:36 AM |
| Page generated in 0.11912 seconds (77.23% PHP - 22.77% MySQL) with 10 queries |
