Finally Pics of my so called "Optimos" amps. Almost finished.
Still to do is the aluminium cover, Blue LED potential divider circuit and an aluminium plate between the PSU and the amp... Hope you like them - they sound great! P.S. Sorry about the long wait! I wanted to keep the image quality. If you can't see those pics use link: http://www.diyaudio.com/forums/showt...2074#post92074 Thanks, Gaz |
#2 |
diyAudio Moderator Emeritus
Looks great! Nice clean, compact chassis design. What are you planning on putting on the top and sides?
How big are the pcbs? Great job! -- Brian |
#3 |
Wow, nice!
It looks like you rolled your own boards? Did you add any features (output protection, etc) to your boards or are they stock? Where did you get the heat sinks?
== John == |
#4 |
Looks nice.
Have you figured out if is the OptiMOS you've built? We've had some discussion about this previously, and I got the impression you weren't sure about this then. The OptiMOS is one of the designs I am considering, so it interesting to hear opinions about it. Do you really need those large heatsinks? Judging from the photos it should be the standard 120W version, so I guess you could manage with quite smaller ones. Not that it hurts with overkill on the heatsinks, of course. I also see that you have quite long leads to the output transistors. I would have preferred a different board layout to avoid that, but if the amps work well it probably doesn't matter in practice. Edit: Just saw that it says 140W in the title. I suppose you just increased the supply voltages a little bit and kept the number of output devices (if it is the OptiMOS, that is)? |
#5 |
I had just written a reply when my PC crashed so here goes again! BrianGT: I am using Aluminium Sheeting to cover the Top, back and front with a 3mm blue LED. The PCBs are 125x175mm, but the actual circuit on the board is slightly smaller... more like 90x170mm. jgwinner: The boards are by my own fair hands! They are by a system called Press 'n' Peel which I highly recommend avoiding!!! Much better to get a UV light and photo-sensetive PCB. The heatsinks were £10 each from Jakeh on this forum. He is very approachable an are stunning quality! There are no extras on the circuit. Christer: I do not believe it to be the OptiMOS circuit. The schematic is slightly different, but the OptiMOS is certainly the closest version to the one I built. It says in the book that it is rated at 140W into 8Ohms and 200W into 4 Ohms when the Power supply is at +- 55V. Since my power supply is at +- 63.1V it will be slightly more. The book says 200W into 8Ohms at +- 68V, so you can do the maths! ![]() The sound is fantastic, but until I build a preamp, I cannot test it with anything but a very dodgy CD player! As I said above, the heatsinks were cheap and allowed me to fit everything in. I'm really happy with the way it's all worked out! Thanks for the comments, and keep them coming! If you want pics of anything in particular, just ask!Thanks again, Gaz |
#6 | |
Any chance you could post the schematic? It would be interesting to compare it to the OptiMOS and the designs in Sloanes power amp book. |
#7 |
Hiya,
Just very quickly, here is the: OptiMOS Design PDF And here is my amp's schematic: EDIT: Hope that helps... Gaz |
#8 |
Press n peel
I have used it a few times and it works fairly well but... It can be a bit tricky. It does not work well at all for large masking areas and wise traces, I always have to fill those in using nail polish. All the problems I ever had with it were in the peel part. If you are peeling and a trace dosen't stick, stop peeling and iron some more. Never peel it all the way off unless you are happy with the result. Getting it to work right can be difficult but is not impossible. The instuctions are not kidding about a band of copper around the project edge, this holds it down so you can be sure that you get all the traces down. If I am not using chips and the circuit is small (like power supplies) I usually make a few drawings, then sit down with the board and use an engraving bit to seperate the traces. Not the sexiest but much faster than drawing it up and etching it. Also congrats on the amp! Looks great
First Audio... Then the darkness control knob on my toaster |
#9 |
Thanks Rarkov,
I would definitely say it is the OptiMOS. As far as I can see it is exactly the same topology with just a few component values differing slightly. I suppose the version on the web page is newer and Sloane has done some tweaking on the exact values of some resistors. As I said, I might choose to build the OptiMOS myself, so its good to hear your positive report on how it sounds. (On the other hand, considering the weather right now I should perhaps go for a huge class-A amp instead ).
#10 |
Sorry...That's my fault...Didn't mean to step on anyone's toes! Therefore, to see the image, you must buy The Audiophile Source Book (Which I highly recommend [grovel grovel!]). You can gt it from Amazon - and is quite cheap. Loads of interesting circuits - not just amps. but protection, preamps, crossovers, equalisers, balanced-unbal convertors etc etc. Please forgive me! ![]() Gaz |
| pics of finished "industrial gainclone" | cowanrg | Chip Amps | 0 | 28th June 2005 07:24 AM |
| Finally completed "Delta" enclosure (pics) | David Gatti | Multi-Way | 35 | 12th February 2005 02:30 AM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Pics of my diy proac 2.5 "clones" | Kermit | Multi-Way | 71 | 21st November 2002 01:20 PM |
| Page generated in 0.12943 seconds (80.24% PHP - 19.76% MySQL) with 11 queries |
