Old 1st March 2006, 03:06 PM   #1
Default using MJL21193/4 in Leach or the M250
Just want to know if we can directly replace the output trans in both amp. with the new MJL's without any modifications?
How about MJ15003/4 in the M250?
M250 at :
http://www.atjoo.hostiz.com//m250.html
Super Leach at :
http://users.ece.gatech.edu/~mleach/superamp/
Old 1st March 2006, 08:40 PM   #2
DIYdo is offline DIYdo  United Kingdom
No problem on the M250 as long as you don't remove the spiking diodes on the output.
I got my finger stuck in my ear!
Old 1st March 2006, 11:29 PM   #3
Hi DIYdo,
You mean both the MJL21193/4 , MJ15003/4 will do?
Old 2nd March 2006, 01:44 AM   #4
djk is offline djk
djk's Avatar
More MJL devices are required due to lower maximum junction temperatures and lower wattage ratings. Check for stability with the faster devices.
Old 2nd March 2006, 10:21 AM   #5
I would go for the MJ devices as the To3 can is superior for heat dissipation. The OPS is configured as EF so will be tolerant to most transistors in terms of stability.
Was just looking at the way the LTP is configured. I would be inclined to reduce the value of C8 to under 20P (or remove completely), Increase R14 to 22k, R15 to 680ohm, and replace R3 with a conection directly to 0v. Having said that I have not built the amp or tested it, I'm sure he has a good reason for doing his design as such.
I notice that there is also no active current limit through the VA stage for when the VI limiting activates. I would be inclined to do something with that aswell. Just my preference anyway.
M250 featherspeed Solid State 3 3rd August 2007 01:57 PM
m250 ldanto Solid State 22 13th March 2007 09:44 PM
p3a vs m250 john-china Solid State 0 23rd February 2006 05:17 AM
the m250 fity Solid State 0 24th January 2006 05:44 PM
M250 Cheese Solid State 1 13th November 2003 05:18 AM
Page generated in 0.07294 seconds (76.95% PHP - 23.05% MySQL) with 10 queries
